Old 09-05-2015, 03:19 PM   #1
matt_field
matt_field's Avatar
Hydraulic clutch help
I'm in need of help mounting master cylinder for my cummins conversion. Any pics or pointer would be great. I've got the factory twist style master cylinder from dodge .
Matt
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 09-05-2015, 04:59 PM   #2
Got Smoke?
Got Smoke?'s Avatar
Re: Hydraulic clutch help
Are you on Facebook? There is a page called GM Square Body Cummin's Swap that has several guys who have swapped trucks. From what I'm seeing there they are using a Ford Master Cylinder NAPA part # 72176, and having a line made to join them to the Dodge Slave cylinder.
97 Dodge 2500 12V NV4500... way to much to list.
79 Chevy K20 4" RC/37" GY OZ's 350/465/205.... restoration somewhere in the futue....
NEW: Project 88 Chevy R3500 3+3 / 88 V3500 3+3 combing two to make one....
Got Smoke? is offline   Reply With Quote
Old 09-07-2015, 09:51 PM   #3
6BT 56
6BT 56's Avatar
I used the bracket that was in the firewall on my 93 ram. Unbolted it and bolted it directly to the frame of my truck . I know that won't work for your app but I'm sure you can fit the bracket in there somewhere.
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 09-09-2015, 11:15 PM   #4
ryanroo
ryanroo's Avatar
I have a treat waiting at the shop for you. I need to put it through QA still, but...
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
