Old 04-29-2015, 08:23 PM   #1
Mathew21
Mathew21's Avatar
Collapsible intermediate shaft?
I'm pulling the front clip off of my truck this weekend. While it's off I was thinking about upgrading to a Collapsible steering shaft. Does anyone have any suggestions for what parts to use?
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 04-29-2015, 09:36 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: Collapsible intermediate shaft?
A lot of good info in FAQ's section.
DPowers is offline   Reply With Quote
Old 04-29-2015, 11:13 PM   #3
franken
90s Jeep Cherokee shaft has a D on one end and splined on the other.
Old 04-30-2015, 04:41 AM   #4
Mathew21
Mathew21's Avatar
Thanks I should of checked there first.
Thanks!
Old 05-08-2015, 05:34 PM   #5
Mathew21
Mathew21's Avatar
I searched the FAQ section. I cannot find anything about using the original column and mounting it to a collapsible shaft. If anyone can point me in the right direction I would really appreciate it.
I do have a 90s Jeep Cherokee shaft has a D on one end and splined on the other. I'm just trying to figure out how you connect the D shape end to the round steering shaft.
Old 05-08-2015, 05:44 PM   #6
doobiebro
doobiebro's Avatar
When I upgraded my 60 stepper with powersteering I ordered the shaft with rag joint and DD steering u joint as a complete kit from CPP.. Never had problems with them and the price was not bad.. here's a pic..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 05-08-2015, 07:22 PM   #7
vince1
I put a 67 shaft into a 66 column but consider myself luck to have found it.
Also check out the Borgeson site if you want more options.
vince1 is offline   Reply With Quote
Old 09-24-2015, 06:53 PM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Do you have the part number?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-24-2015, 07:42 PM   #9
I used a 69 C10 column and intermediate shaft.
Old 10-07-2015, 09:32 PM   #10
LostMy65
LostMy65's Avatar
Does anyone know what part number this is?
Old 10-07-2015, 10:10 PM   #11
LostMy65
LostMy65's Avatar
Okay,
I found them @ CPP.
I don't know which one will work with a 65 steering shaft, and a 77 power steering gear.
Originally Posted by CPP
1" -48 column u-joint, 3/4" -30 rag joint, each
$119.00
Buy
CSS-1487361" -48 column u-joint, 3/4" -36 rag joint, each*
$119.00
Buy
CSS-1488361" -48 column u-joint, 13/16" -36 rag joint, each*
$119.00
Buy
CSS-1DD7301" DD column u-joint, 3/4" -30 rag joint, each*
$119.00
Buy
CSS-1DD7361" DD column u-joint, 3/4" -36 rag joint, each*
$119.00
Buy
CSS-1DD8361" DD column u-joint, 13/16" -36 rag joint, each*
$119.00
Buy
CSS-7367303/4" -36 column u-joint, 3/4" -30 rag joint, each*
$119.00
Buy
CSS-7367363/4" -36 column u-joint, 3/4" -36 rag joint, each*
$119.00
Buy
CSS-7368363/4" -36 column u-joint, 13/16" -36 rag joint, each
Old 10-07-2015, 10:33 PM   #12
65 GMC
I have a 65 GMC with a 78 GMC power steering box. I used the collapsible shaft from the 78 GMC with an aftermarket u-joint from Sweet Mfg. It seems like it will work out pretty good. It also takes out any tension that would otherwise be on the steering column bearings from spacing the steering box out with an adaptor plate. Here are some photos of what I did before I welded it all in place. The last photo is the part# of the u-joint I used.
65 GMC is offline   Reply With Quote
Old 11-14-2015, 09:11 PM   #13
LostMy65
LostMy65's Avatar
Would you happen to have the part number?
Old 11-16-2015, 06:14 PM   #14
doobiebro
doobiebro's Avatar
Let me go through all my truck invoices I have put away. I should find something tonight.
Old 11-16-2015, 07:55 PM   #15
LostMy65
LostMy65's Avatar
thank you. I don't need it necessarily tonight
I'll probably order it on Black Friday.
Old 11-16-2015, 08:48 PM   #16
AcampoDave
AcampoDave's Avatar
So you cut the stock shaft to mount the u-joint?
AcampoDave is offline   Reply With Quote
Old 11-16-2015, 08:59 PM   #17
LostMy65
LostMy65's Avatar
Yes,
but if converting to power steering, we already will be cutting the shaft.
We have to shorten it when we convert to power steering.
Old 11-16-2015, 09:05 PM   #18
aotte1
This is how it was done on 64 K10 project, a little more description is provided in build. Description below is from build.
"Going with a Borgeson collapsible steering shaft and two universal joints, for safety and tighter steering.
The 1983 K10 gear box steering shaft has 30 splines ( Used on this on project to convert to PS), the rag joint will be replaced by a lower universal joint. The steering shaft will be shortened to accept the collapsible universal shaft. The upper universal joint has a double D connection to original shaft, and the original upper part of the steering shaft will be modified to accept the double D universal joint end. This modification is easily reversed by replacing with an original shaft." Post photos of set-up when complete in build " 64' K10 Project Long Bed".
Les
aotte1 is offline   Reply With Quote
Old 11-16-2015, 09:54 PM   #19
aotte1
Photo installed.
Old 11-16-2015, 11:03 PM   #20
doobiebro
doobiebro's Avatar
Okay Lostmy65....depending on what gearbox year and how many splines I went with a 67-72 C10 p/s gearbox.. It came with 36 spline and you will have to match the rag joint..I personally never had a problem with CPP and have used them for two builds...they will gladly help you out so call them. Here are the part #s..
(RJC836-CS) RAG JOINT & COLAPSIBLE SHAFT 13/16 36 RAG 70-81 CAMARO
(CPP-UJ7) STEER U-JOINT 1DDX3/4 DD
Old 05-11-2017, 07:20 PM   #21
LostMy65
LostMy65's Avatar
After more reading and research, I want both collapsable and Vibration Reducer.
Any recommendations?
Old 05-12-2017, 11:16 AM   #22
Pinchecharlie
65 steering shaft is 3/4 round. The steering gear box may be different splines but the one I used of a 84 was 3/4 30. Better measure and count the splines. I pulled my shaft and had a machine shop DD the last inch (40 bucks) then used a borgelson joint 3/4 DD to attach an intermediate shaft (cut to fit from speedway) then the rag joint . Basically a joint at.the stub of your steering shaft- you deciede-DD? Weld on 3/4 round or 3/4 pinned? And each joint can be ordered with whatever end you want. Example-3/4 round weld on to 1 inch DD . Or 3/4 DD to 3/4 DD. Many styles and sizes but most common are 3/4 DD and 1 inch DD. When we used to race circle.track we would just weld 3/4 round because it was easy and cheap, not safe but .. The cpp intermediate shaft looks to be the way to go. Just machine your steering shaft end.to DD and count your gear box splines,order 3/4 DD to x splines, measure , cut and bolt it on. They are very forgiving joints. But don't do what I did and cut it to short lol!
Pinchecharlie is offline   Reply With Quote
Old 05-12-2017, 02:27 PM   #23
The Rocknrod
Moderator
The Rocknrod's Avatar
Borgeson makes a u-joint that incorporates a vibration reducer.
Old 05-12-2017, 06:24 PM   #24
LostMy65
LostMy65's Avatar
Thanks, I sent an email to them.
I'll post back what I end up with.
Old 05-12-2017, 06:42 PM   #25
The Rocknrod
Moderator
http://www.flamingriver.com/index.ph...ts/c0005/s0010
http://www.borgeson.com/xcart/home.php?cat=3
