Old 12-21-2015, 12:33 AM   #26
steveperry
Re: Swapping a 69 Chevy body onto a 97 Cummings chassis
And I've got a question. Does anyone know what this little box does? It's got what look to be vacuum lines coming off of it, can't figure it out. Doesn't help that the guy that I bought the truck from had a bunch of it disassembled before I got it...
steveperry is offline   Reply With Quote
Old 12-21-2015, 03:47 AM   #27
Maxxd07
Maxxd07's Avatar
That valve is for an exhaust brake. Looking at your first picture it looks like there is an air cylinder by your turbo and that would close a flap in the exhaust to slow the engine down during deceleration. I bet there is also a switch on the fuel pump that will only allow power through when the throttle lever is at idle.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 12-21-2015, 08:59 PM   #28
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice project you have going on here. I would try to install the intercooler now rather than not using it. If you plan to keep the engine near stock HP levels and don't plan to tow, than you can get away without one. If not, plan to install one. You have the dodge fan, why not use it? It's more reliable than an electric fan.
Ryan
1969 Chevy milk truck
Old 12-21-2015, 09:17 PM   #29
steveperry
Yeah, I'm going to use the intercooler, going to work on fabbing up the cab mounts on the dodge frame tomorrow and then start getting the front clip on and start the figment process. The only reason I wouldn't use the dodge fan is for clearance issues. The front axle on the dodge is further back than the Chevy so I have to do some playing around with the placement of the cab to make it all work. I'll update as I make progress.
Old 12-22-2015, 01:55 AM   #30
steveperry
Worked on getting that damn p-pump out for the better part of an hour and just couldn't get the inner bolt to break loose. Anyone have any suggestions? Gonna try a universal on it tomorrow, couldn't find mine tonight. But I got the opposite side of the engine stripped down. Going to reassemble after I get everything cleaned up and the gasket kit gets here.
Old 12-22-2015, 10:48 PM   #31
Dieselwrencher
Which inner bolt are you referring to? One of the inner retaining nuts? I use a u-joint type swivel socket and a 12-16" long extension to get to them. It looks like you have some exhaust manifold bolts to extract too. Super fun. Haha
Ryan
Old 12-23-2015, 02:03 AM   #32
steveperry
Got the p pump off! That was the ticket, the universal, popped right off. And yes....I've got four manifold bolts to extract! But I started degreasing the engine this evening with mineral spirits, hadn't ever heard of it but it works amazingly well to get all that road grime off. And anybody know what that box looking deal is toward the back of the block with what looks to be a coolant line connector coming from it? It was behind the p pump and the hose was broke off of it, wondering what it's for.
Old 12-23-2015, 09:03 PM   #33
Dieselwrencher
If you're referring to the tan colored piece, that is the tappet cover. The box with the tube coming out of it is the breather. That is the only breather on the engine. There is a packing in there to help seperate oil from excess crankcase pressure as it exits the block. A road draft tube is usually attached there with a spring clamp and it is routed in between the starter and engine block stock. 3/4" hose to be exact.
Ryan
Old 12-25-2015, 02:21 AM   #34
steveperry
Got my gasket kit and fass system! Christmas came early!! Time to start resealing this pig and get her put back together! Even got the wife to help strip some of the gunk off the chassis!
Old 12-25-2015, 04:08 AM   #35
steveperry
Here's some before and after of the clean up, looking pretty good I think.
Old 12-27-2015, 01:02 AM   #36
1972RedNeck
1972RedNeck's Avatar
Subscribed
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 12-27-2015, 06:34 PM   #37
72 tigger
72 tigger's Avatar
Tried to get cab mount pics
72 tigger is offline   Reply With Quote
Old 12-27-2015, 06:39 PM   #38
72 tigger
72 tigger's Avatar
Rear mount
Old 12-27-2015, 08:29 PM   #39
steveperry
Got the old front cab mounts cut off the dodge frame and gonna start measuring for the Chevy cab, should have some fabbing done up by the end of the week! Don't mind the nest of wires there on the transmission...it'll get sorted out eventually. Thanks for the pictures there tigger!
Old 12-27-2015, 08:58 PM   #40
steveperry
Was just thinking...if the front of this truck is such a tight squeeze with the inter cooler and all, I'm gonna get an extra couple fenders and cut out about four inches in front of the wheel and slice another fender in the same spot. Splice in the extra length, will give me more space out front, line up my fender over my wheel properly, and allow me to keep my cab a little further back. Anyone tried this? Cause I'm thinking this will be just about a perfect fix for the tight squeeze/wheel placement problems.
Old 12-27-2015, 10:57 PM   #41
steveperry
I did a little wood working tonight and thought that it'd be easier to build a form or jig if you will of the cab mounts to figure out where to weld my mounts on the truck. The horizontal bars are as wide as the flat portions of the front and rear cab supports so as you see on the rear mounts they would have to be put through the frame, not a fan of this idea. So I'm going to move the nut plate that is in the cab out to the end of the flat portion of the cab support and drill a new mount hole, and weld the bracket in. This will give me enough room I think to keep the original style cab mount bushing stack up and keep from cutting into the frame. The front is clear by a good couple inches! So that's good news!
Old 12-29-2015, 12:19 AM   #42
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Cool build!
Here's another Chevy cab on a cummins/dodge chassis: http://www.67-72chevytrucks.com/vboa...d.php?t=178608
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 12-29-2015, 10:27 PM   #43
72 tigger
72 tigger's Avatar
Found some old notes from my build in 2003. The bed mounts are the highest point (obviously) which I called 0 - the rear cab mounts are 3 1/4" below them- the front cab mounts are 5 7/16" below the bed mounts & the rad supports are 3/4" below the bed mounts. Don't know if this helps (& I would triple check them if you use them) but, thought they could be useful.
Old 01-08-2016, 01:49 PM   #44
Luther Grimace
Luther Grimace's Avatar
Awesome project. You will have a stout truck that drives like a late model Dodge. I did a Chevy cab swap onto a Cummins frame. Link is in my sig. I'm not sure if it will help you because I used a 55 Chevy and a First Gen Cummins truck.
Dieselwrencher may know more about this than I do on a P pump truck but I don't run a fan at all, mechanical or electric. This freed up a lot of room for me. Mine is also a VE pumped engine though. The P pump can put out a lot more fuel which would relate to heat.
Also, I reused the Cummins truck radiator support. This saved time mounting the radiator and intercooler.
If I had to do it again I would try to get by without the intercooler. It was a ton of work to make it fit. Including cutting the firewall and sectioning a wheelbarrow in.
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 01-09-2016, 01:40 AM   #45
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Oh yeah I forgot ^ he used a dodge chassis. Check it out, his is sweet!
Tony
Old 01-09-2016, 11:47 AM   #46
steveperry
Re: Swapping a 69 Chevy body onto a 97 Cummins chassis
Thanks for the link! Any and all ideas are welcome, I'm going to get the front cab mounts done up today and set the cab on the chassis. I'll put up pictures as soon as it's done. Then I can start playing with the clearance issues up front.
Old 01-09-2016, 03:23 PM   #47
steveperry
Finally got back to working on the truck some. Welded the front cab mounts on and set the cab on the frame for a test fit. It's so cool to see the cab on that frame!! Gotta work on the final cab placement and how to center the axle in the fender but I knew that was coming.
Old 01-09-2016, 06:21 PM   #48
72 tigger
72 tigger's Avatar
Lookin' good!
Old 01-11-2016, 01:07 AM   #49
steveperry
I've got a question for you diesel knowledgable people out there. I've got the fass system for the 12v and was doing some thinking about the stock lift pump...I don't need it anymore right? And the fuel bowl/filter on mounted on the back of the intake? The was I understand it is the fass system has both of those things built into it, so why keep the old stock stuff? Looking to clean up some junk in the engine bay if it's mechanically sound to do so.
Old 01-12-2016, 02:52 AM   #50
Dieselwrencher
Do you know which model of fass pump it is? The truck is looking nice. Keep up the great work!
Ryan
