Old 08-08-2016, 08:52 PM   #26
Dustmaker65
Dustmaker65's Avatar
Re: FS: BBC/TH400 No Hole High Hump Tunnel Covers
I will take it...pm payment info.
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 08-08-2016, 08:58 PM   #27
General23cmp
Thanks! I really appreciate it. Classic, I'll PM you to discuss payment and how to ship.
General23cmp is offline   Reply With Quote
Old 08-08-2016, 09:05 PM   #28
General23cmp
Wow Dustmaker, you were quick. There was a line on the hump
Old 08-09-2016, 07:12 PM   #29
Classic Bowties
Always on the hunt...
Originally Posted by General23cmp View Post
I'll get in line for the green one if Eagle doesn't do it. Cost to ship to 35613 residential? I'd probably go with the cut option. Just the three nut plate sections, bolts, and tunnel. Don't need what's left after that. Thanks.
Out of curiousity, how are the nut plates attached? Are they spot welded, tack welded on whole edge, tacked in a few spots, glued, etc? Thanks.
Shipping cost on the green BBC auto trans high hump with floor ring to Athens, AL. 35613 (Res.) is $36.54 sent via Fedex ground, total transit time would be 4 business days. The nut plates are spot welded to the floor pan, will remove floor pan ring and cut as mentioned above and send all pictured. Payment can be sent via paypal, U.S. postal money order or credit card over the phone. Thanks, Mel.
Classic Bowties is offline   Reply With Quote
Old 08-09-2016, 08:19 PM   #30
General23cmp
PayPal on its way. $150 + $36.54 = $186.54. I'll PM you to confirm shipping info.
Old 08-10-2016, 05:17 PM   #31
Classic Bowties
Your payment came through just fine, still need the pm confirming your full shipping address and a contact number. Also wanted to confirm again (as posted above) everything pictured will be sent, the floor ring will be cut down for easier packing & shipment. Thank you, Mel.
Old 08-10-2016, 06:04 PM   #32
General23cmp
Thanks. I did send the PM. Let me know if you didn't get it. Name, address, and number were included.
Old 08-12-2016, 02:53 AM   #33
Classic Bowties
The high hump tunnel cover w/floor pan ring is headed your way, parts were shipped out fedex ground insured on Thur. 08/11, fedex projected that you should see the box Tue. 08/16 by the end of the day. Here are a few more pics showing the floor pan section after being cut down and prepped for shipment, bolts were threaded back into the nut plates. Thanks again, Mel.
Old 08-12-2016, 08:02 AM   #34
General23cmp
Thanks!
Old 03-29-2017, 02:23 PM   #35
GarrettPhillips
Still have any left?
GarrettPhillips is offline   Reply With Quote
Old 03-29-2017, 03:29 PM   #36
Classic Bowties
Yes, we have some more high hump tunnel covers pulled. Are you looking for a specific high tunnel cover (motor/trans combo C/2wd or K/4wd)? I can check out and get some pictures of what we have pulled later today. Mel
Old 04-11-2017, 08:43 AM   #37
Phill0406
Phill0406's Avatar
Interested in a high hump as well. No holes preferably, let me know what ya got! (for a c10 2wd column shift)
Phill0406 is offline   Reply With Quote
Old 04-15-2017, 03:52 AM   #38
Classic Bowties
To try and keep things straight we just posted the most recent high hump tunnel covers in the below linked F/S thread, you can have a look there. Thanks, Mel.
04/15/17 Thread Link: http://67-72chevytrucks.com/vboard/s...=1#post7916250
