#26 |
![]() Join Date: Apr 2013
Re: 69 C10 SWB choppin block full build thread!
Sounds good
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
#27 |
![]() Join Date: Mar 2016
![]() chassis and rear end came back from the sandblaster... time to fill some holes do the cutting and add some ridgidity. the rearend will be going to my friends shop for hot tank and then it will get re-blasted and coated with the chassis.... i already have a new posi unit and gears and bearing waiting along with a moser 5x4.75 pattern rear axles and these fancy new 4 piston wilwoods ![]() ![]() gas tank also came in along with the front brakes which are 4 piston wilwood with a 12.8" rotor time to get some stuff knocked out! finally found a seat at the boneyard last saturday too... time to shorten it up and get her covered! |
#28 |
![]() Join Date: Dec 2012
Very nice!
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
#29 |
Looks like a nice build
Seth Instagram: sethrosa11 My Build Thread: "Betty" http://67-72chevytrucks.com/vboard/s...d.php?t=613225 1966 C10 Patina: http://67-72chevytrucks.com/vboard/s...d.php?t=716802 1978 Big 10 http://67-72chevytrucks.com/vboard/s...d.php?t=771383 |
#30 |
Any updates, opinions on the chopping block suspension?
#31 |
![]() Join Date: Jun 2009
Looks like the perfect candidate for a build
![]() ![]() Even though he has not been on here since mid October
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
#32 |
In for some updates. Looks like a great start!
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
#33 |
Post #20.... He stated he changed directions & was leaning toward a Ride Tech Stage-2 Coil Over set-up.
#34 |
Yea I noticed that after I posted. I havn't really heard much about the chopping block suspension that azproperformance is selling, I thought that's what he was running from the title. Thanks
#35 |
![]() Join Date: Dec 2014
He did go with Ridetech coil overs.
