01-28-2017, 04:40 PM | #4901 |
Re: What did you do to your truck today? Chapter II
Not a darn thing done on the truck today, busy in Matera, Italy working on another classic piece of iron..... it is a 72 however.... good patina as well! Lower roller shafts are worn so it's got a drop kit I guess you would say...
01-28-2017, 06:14 PM | #4902 | |
Andy4639 i dont see anything wrong with that ....looks good to me ....Don |
01-28-2017, 06:24 PM | #4903 |
Old member
Thank you sir. I'm pleased with how it's looking so far. I just need a rubber floor mat. I have the tilt and steering wheel + the dash pad to install yet but that maybe awhile until I can get the tilt rebuilt.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-28-2017, 07:49 PM | #4904 |
Oil change, coolant flush. Replaced my temp sending unit to no avail. .. oh and then grounded the 12 volt peg of my temperature gauge.... Now when I ground the temp wire it wont peg out to hot... Did I fry her? Did I just burn out the ceramic resistor? Blow a fuse that I don't know about? I've been through the manual and these threads a little. Anyone have any thoughts as to the damage I did? Know of any other threads discussing this business? Btw, first time posting! This forum is great and I am very thankful!
01-29-2017, 05:21 PM | #4905 |
i have a bunch of tilt steering parts if you need them , just let me know .i can box them up and send them your way ....Don
01-29-2017, 06:01 PM | #4906 |
Whats with the bolts on the fillers pieces at the latch assembly? Can I get some info on what you used there?
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
01-29-2017, 06:09 PM | #4907 |
I have the same kit... let me know how it works since Im still so far away from any driving...
01-29-2017, 06:11 PM | #4908 |
got these door panels on ebay for $20. added woodgrain and some chrome trim. then I thought I would add the woodgrain and chrome to ashtray.
01-29-2017, 06:17 PM | #4909 |
wrong picture
01-29-2017, 06:20 PM | #4910 |
Started my day off with a board meeting, it went well. Got most of the cutting done and shaped. New tunes for summer.
01-29-2017, 11:58 PM | #4911 |
I'm a day late, but I got a bed to replace the farm boy special on my truck when I bought it.
1969 GMC 2500. 250 I6, 4-speed w/ granny low |
01-30-2017, 12:57 AM | #4912 | |
https://allamericanbilletstore.com That's where I got mine from... I'm very happy with them |
01-30-2017, 09:27 PM | #4913 |
Changed the tranny fluid, rear gear fluid, repacked the front bearing, checked all the brakes then a good cleaning for both Holdie and Samson. Been a great day.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
01-30-2017, 09:29 PM | #4914 |
Another
01-30-2017, 09:33 PM | #4915 |
Goldie
01-30-2017, 09:34 PM | #4916 |
Wish I could figure out how to post more than one at a time.
01-30-2017, 10:52 PM | #4917 |
CST10-Two nice trucks you have! You should be able to post 5 pics but upload one at a time. go ADVANCED scroll down to Manage Attachments then brose your pics and upload each one add a short note and 5 at a time will attach. Hope this helps.
01-30-2017, 11:47 PM | #4918 |
laying low
I'm a stepside man but I got to tell you that white fleet just looks absolutely classy. Solid white and all trimmed out is hard to top.
01-30-2017, 11:48 PM | #4919 |
Changed exhaust manifold "donuts" in my 69 k/10 and took a test run to the beach--good place to clear my mind what ever is left of it! Lots of water out there-3,700 miles or so to Europe.
01-31-2017, 01:37 AM | #4920 |
Halfway done under the dash, new wiper motor, Man that was a PITA. I was not made to bend that way. New bolts for the heater fan switch assembly and put in a Never Pop control upgrade for it.
Will post a pic soon! Its nice to have wipers again |
01-31-2017, 08:54 AM | #4921 |
X2 with the drop...
1970 C10 Short Stepper with 71/72 front clip. |
01-31-2017, 09:23 AM | #4922 |
Thanks! Got the new windshield put in today.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
01-31-2017, 12:35 PM | #4923 |
Replaced radiator. Had to drill the spot welds on the saddles and emove them thus only using the actual bracket and rubber to hold the new rad in. It was too big. Guess ill order some 4 core saddles. Also installed new heater core. That was fun. The rubber stuff that seals it up held it there REALLY well. Thought I might break the case trying to pry it off the firewall. That was yesterday. Today will be filling with coolant and checking for leaks and hoping I finally have heat and a sealed cooling system!
http://67-72chevytrucks.com/vboard/s...25#post7532025 71 Cheyenne K10. 283/Th350/NP205. 3.07s non posi. 31x10.5 Bighorns.L31 350 Vortec swap in progress. 79 Suburban K20. 350/350. 6" lift. 35x12.5 Toyos. 93 Burb K1500. 350/4l60e Parting out. 2001 Tahoe LT, 5.3, autoride, 265/75s, leather, loaded, family hauler, 243k miles! |
01-31-2017, 08:47 PM | #4924 |
I let mine stretch its legs by driving it to work. I'm just waiting for the weekend to continue tearing down the bed I bought last weekend.
01-31-2017, 10:18 PM | #4925 |
Minor improvement.
I got tired of looking at my grungy looking alternator, so I pulled it out, and cleaned it up. Gave it a light coat of bright silver, along with repainting the pulley and fan blak. Didn't take long or cost much, and looks 100% better than before. Sorry, no pic. It was dark when I finished |
