Old 12-01-2017, 09:18 PM   #1
Submariner616
Active Member
Need original steering u-joint seal 60 C10
Looking for new rubber seal for the steering column u-joint on my '60 C10, or entire assembly. I found a company that makes complete reproduction units of this assembly, but not for GM. I searched the web, including ebay, with no luck. Does anyone know where to find this? Thanks!!
Submariner616
1965 Chevrolet K20 350 4 speed manual
Submariner616 is offline   Reply With Quote
Old 12-02-2017, 09:40 AM   #2
62 Barnfind
62 Barnfind's Avatar
Re: Need original steering u-joint seal 60 C10
Submariner616,
I was having a few problems with my 62's column also. It was basically just worn out and I didn't want to keep messing with it. I replaced it with an I did it column and i am so happy I did. No issues, and an easy install. The only thing is your still running a 3 speed on the column you will have to put in a floor shifter.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 12-02-2017, 01:59 PM   #3
Submariner616
Active Member
Originally Posted by 62 Barnfind View Post
Submariner616,
Thanks John Z. It's a two speed power glide. The truck is so stock, so complete, and so original I am struggling to keep it that way as I do the complete restoration. The steering works fine, I just want to clean this up and put a new seal or boot on it.
It is very hard to resist the temptation to modernize this beautiful hunk of steel!!
Submariner616
Old 12-02-2017, 09:19 PM   #4
AcampoDave
AcampoDave's Avatar
Wow, my '64 has a one piece rod. I just figured they were all like that. Is that a automatic tranny only deal?
AcampoDave is offline   Reply With Quote
Old 12-03-2017, 12:25 AM   #5
Captainfab
60-66 Nut
No, it's just a '60-'62 deal.
Old 12-03-2017, 06:48 PM   #6
rvrfoot
We need to find the seals for the 60 62.
rvrfoot is offline   Reply With Quote
Old 08-26-2023, 12:42 PM   #7
Ledslinger
I'm reviving this old thread because I found a pretty much exact replacement for this seal and its readily available:
https://www.amazon.com/gp/product/B0...3AWUYIR8&psc=1
Ledslinger is offline   Reply With Quote
