Old 06-23-2018, 09:28 AM   #176
Dads79GMC
Dads79GMC's Avatar
Re: Sparky's 1978 Silverado Build "Addiction"
Originally Posted by BIGglaSS View Post
Lookin' good. I'm taking notes...
Originally Posted by MrFinland View Post
Nice work Mike!
Thanks fella’s!! I need to clean my garage, get a pile of boxes recycled, then head to the landfill with other “stuff!”
Thanks Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 06-23-2018, 06:07 PM   #177
Dads79GMC
Dads79GMC's Avatar
Well, started to clean the garage after going to the landfill, however, I got distracted with other things.
Pictures:
1. Put the wheels and caps on...distraction number one..cascaded from there!!
2. Got a little ambitious and hooked the LS to the picker!!
3. Installation went smoothly when I got the boy involved.
4. Fits well.
5. Checking driveshaft. The truck spent a lot of time out in the elements with the box off, you can see some of the pitting on top of the frame, still sturdy though!!
Also replaced the camaro exhaust manifolds with Hooker exhaust manifolds, then installed Hooker's down-tube thingy's with the bung for the O2 sensors.
The left air bag is leaking....I believe I didn't push the tubing into the fitting all the way when I was in a rush, it takes about an hour to deflate the airbag. Gonna have to fix that tomorrow.
Gonna head to JaysonB's tonight and run him some parts. Garage aint gonna get cleaned today. Lol!!
Thanks Mike
Old 06-25-2018, 09:08 AM   #178
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks good. Does the panhard bar clear the rear end pumpkin when the suspension is completely air'd out?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-25-2018, 11:14 AM   #179
Dads79GMC
Dads79GMC's Avatar
Karl, as it is now, no. I will have to adjust the panhard bar at some point. The bracket holding the bar will have to be moved inward toward the pumpkin about 1/2 an inch and point a little skyward in order to clear the pumpkin when the truck is air'd out. Thanks Mike
Old 06-26-2018, 11:55 AM   #180
Dads79GMC
Dads79GMC's Avatar
Had to do something last night so I put some epoxy on a couple bed pieces that had been blasted and picked up on Friday. I’m waiting on some upper air bag brackets that are being fabricated for me so I can finish the rear of the frame. Thanks Mike
Old 06-27-2018, 09:57 PM   #181
Dads79GMC
Dads79GMC's Avatar
Always have to be doing something truck related!! Tonight I shuffled around the garage. I put the frame aside and will focus on the cab for a few days. I’m still waiting on my two upper brackets for the rear air bags. I found some time to do a little more welding and grinding on the cab. Mike
Old 08-02-2018, 10:14 AM   #182
Dads79GMC
Dads79GMC's Avatar
Started to lay out the bed pieces again. I’ll need to get a lot in epoxy primer this weekend.
Old 08-02-2018, 05:41 PM   #183
moregrip
moregrip's Avatar
there it is, been waiting on this update!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 08-02-2018, 06:15 PM   #184
Dads79GMC
Dads79GMC's Avatar
I know, I know! More to come!
Old 08-03-2018, 10:19 PM   #185
Dads79GMC
Dads79GMC's Avatar
Tonight I put the front steering components together and aligned the tires as close as I could get them until it gets aligned professionally down the road. Mike
Old 08-26-2018, 11:41 PM   #186
Dads79GMC
Dads79GMC's Avatar
Kind of jumping around!! Today I worked on the underside of the cab, tediously slow work!
Mike
Old 09-01-2018, 11:20 AM   #187
SBTork
Garage wrench
SBTork's Avatar
Looking great!
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 09-01-2018, 11:33 AM   #188
Dads79GMC
Dads79GMC's Avatar
Originally Posted by SBTork View Post
Looking great!
Thanks SBTork!
Old 09-02-2018, 09:41 AM   #189
LT7A
Great progress. So cool that you are building two trucks of this caliber. And one in honor of your Dad. Keep up the good work -- Jayson too! And thanks for showing us the process.
Old 09-02-2018, 11:28 AM   #190
Dads79GMC
Dads79GMC's Avatar
Smile Re: Sparky's 1978 Silverado Build "Addiction"
Thanks LT7A. I’m running out of time!
Old 09-10-2018, 07:29 PM   #191
Dads79GMC
Dads79GMC's Avatar
Sloooooooooow progress! Mike
Old 09-10-2018, 09:28 PM   #192
Dads79GMC
Dads79GMC's Avatar
Got the second coat of epoxy on the bottom of the cab (still wet). Tomorrow I will seam seal, let dry, then undercoat. Looks like I still have some welds to grind down
Mike
Old 09-10-2018, 11:07 PM   #193
Jaysonb
Jaysonb's Avatar
Looks good Mike!
Jaysonb is offline   Reply With Quote
Old 09-11-2018, 10:47 AM   #194
aggie91
aggie91's Avatar
Great work. What are you going to use for undercoating? On my last one, I used black Raptor liner and was very pleased with the results.
Karl
The LST Challenge:
Old 09-11-2018, 11:09 AM   #195
Dads79GMC
Dads79GMC's Avatar
Thanks aggie91! Sorry for the loss on Saturday, great game! I have some 3M undercoating the bodyshop store here in town recommended. Bottom turned out better than I thought it would, I have a good mentor!! Thanks Mike
Old 09-11-2018, 11:10 AM   #196
Dads79GMC
Dads79GMC's Avatar
Originally Posted by Jaysonb View Post
Looks good Mike!
Thanks Boss
Old 09-11-2018, 09:06 PM   #197
Dads79GMC
Dads79GMC's Avatar
Should be able to flip it upright tomorrow after it dries overnight. It's still a little soft to be pushing around. I'm in a hurry because i think the other one will be coming home soon!!!
Thanks Mike
Old 09-11-2018, 10:33 PM   #198
Jaysonb
Jaysonb's Avatar
Now that you have all the hard dirty work done, just haul it up with you and we can get it knocked out next!
Old 09-11-2018, 11:49 PM   #199
Dads79GMC
Dads79GMC's Avatar
Don’t tempt me!!!!!
Old 09-18-2018, 10:16 AM   #200
Dads79GMC
Dads79GMC's Avatar
Last night I was able to put the cab back on the dolly and get it upright. I also removed all the various screws and other fasteners on the firewall. I’m running out of time, need to get this project back on track! Thanks Mike
