04-26-2019, 09:01 AM | #1 |
Passenger Side Frame Rail Question
I have question about the right hand frame rail on my '67 C10. On the top of the frame rail just in front of the front C member there is a bump in the rail. I thought this bump might have been caused by someone straitening the frame as the front stubs shows signs of an accident. But I looked at a picture of frame for sale and it had the same bump in the rail.
The question is do all '67-72 frames have this bump in the RH frame rail? |
04-26-2019, 10:10 AM | #2 |
Re: Passenger Side Frame Rail Question
I beleive the bump you are talking about would be for fuel pump clearance, all the frames had this.
04-26-2019, 12:24 PM | #3 |
That would make sense. The guy at the frame shop said it was from where they pulled on the frame to straighten it from a previous wreck. The front stubs still don't look right so I want to replace the frame. Since the frame I am looking at to replace it has the same bump your explanation makes more sense. Thanks.
04-26-2019, 04:14 PM | #4 |
All about them K’s
Pictures will probably help us know what’s going on...
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
04-26-2019, 06:39 PM | #5 |
Nope. The ''bump'' is normal. Your frame shop guy doesn't know what he's talking about, and is trying to scare you into some expensive and unneccessary straightening. Look for a new shop.
04-26-2019, 06:46 PM | #6 |
Most body shop employees now days are trained for the new process of work and has not a clue about metal from the 60's on up to the mid 80's . have to remember we have t shirts older than most mechanics and body shop employees, we are a dying breed sad to say.
04-26-2019, 10:06 PM | #7 | |
If you go down the list of substances formerly used in the automotive trade, you might get a clue as to why our ranks are thinning. Lead [TEL], asbestos, MethylEthylKetone [MEK], Zinc chromate primer, hexavalent chromium used to work so well in those cans of carb dip. Haven't seen that stuff for a while. I guess we're too ornery to kill.
04-27-2019, 10:43 AM | #8 |
Well I had some good news and bad news yesterday. Good news is the bump is to clear the mechanical fuel pump. Met a guy who had a C10 and he showed me it. Bad news is I did some measuring on my frame and confirmed it is bent. So now the search is on for a replacement frame.
