07-18-2019, 12:31 AM | #1 |
Before and After
Lets see your Air Management Systems.
How did you set up your air tanks and compressors?
Are they accessible through the bed? Bed lifts? I want to see them all, good ideas and those that you regret for whatever reason.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
07-18-2019, 03:26 AM | #2 |
Re: Lets see your Air Management Systems.
Neatly tucked under the raised floor
Customization is what you want it to look like -- not what other people think it should look like |
07-25-2019, 10:28 PM | #3 |
Before and After
Nice Idea, How did you determine where the lift rams were to be placed?
Is it just a standard hinge? is the entire bed floor removable if you need to work on the system?
07-26-2019, 02:05 AM | #4 |
The gas shock placement had to do with height on opening and smooth operation on closing.
The hinge system is the same as a hard tonneau cover, but modified slightly for my application. Yes, the floor is completely removable and I have used it as a picnic table once. One end stayed on the truck and I had two makeshift legs for the other side. I slid it out to where I needed it and had a good ol time at a truck meet.
07-26-2019, 07:55 AM | #5 |
I wanted an air ride set up on big red, until I was quoted starting price of 9k in Australia
