09-08-2019, 01:48 AM | #1 |
72 gmc Sierra grande stuck in 4 wheel drive
I have a 72 gmc Sierra grande 1/2 ton 4x4 that is stuck in 4 wheel drive. It has a 205 transfer case. I cant get the transfer case shifter to move and the hubs wont unlock either. Any suggestions or advise?
68 Chevy CST Short Bed, 70 Chevy CST Short Bed, 70 Chevy Short Bed 4X4, 72 Chevy Cheyenne Super 4X4, 72 GMC 1/2 Ton 4x4 Sierra Grande, 72 Chevy 1/2 Ton Big Block Suburban Highlander, 72 Chevy 1/2 Ton 4x4 Suburban, 72 Chevy 1/2 Ton Cheyenne Super, 72 C50 Custom, 69 Chevy CST C30 tow truck, 71 Chevy Big Block C30 |
09-08-2019, 08:30 AM | #2 |
Re: 72 gmc Sierra grande stuck in 4 wheel drive
Prolly shift linkage froze. Spray some penetrating lube on the pivot and the cross bar where hooks to the shift rails. I had one freeze on one. Hubs won't unlock cause there is tension on the driveline.
09-08-2019, 08:57 AM | #3 |
20' Daredevil (Ret)
If it's been driven on a hard surface (like pavement) the driveline might be bound up. Try driving slowly in reverse while steering left & right. If it's still bound up you might have to jack up a front tire, then you should be able to release that hub and take the TC out of 4WD.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
09-08-2019, 11:08 AM | #4 |
Thanks I will try those things!
09-08-2019, 12:27 PM | #5 |
i like napa chain and cable lube . its a foamy oil that sticks real good for lasting lube . also spray the rails that go in the case the link bar is hooked to .
as said she is just bound up a bit .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
10-17-2019, 12:40 AM | #6 |
any update?
