Starting Engine On Frame?
Hey Guys Just Looking For Some Tips and Advice To Start My Engine On The Frame. Have Everything Plumbed. Radiators Hooked Up. + Battery Wire To The Starter
Just Not Sure About The Wiring. Was Going To Use The Keyed Ignition To Turn It Over.. Its An HEI Distributor Posted via Mobile Device |
Re: Starting Engine On Frame?
I'm not sure what you mean. The engine should be on the frame.
Last edited by LockDoc; 01-17-2020 at 11:29 AM. Reason: We don't correct people for the way they type on this forum. |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
Why the attitude when you have nothing to contribute?
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
Make sure its not in gear. 12v to HEI, jump terminals on starter with a screwdriver or a switch.
![]() Join Date: Dec 1999
I would do like Mike C says and jumper 12v to the HEI and use a remote start button like this:
https://www.amazon.com/Sunpro-CP7853.../dp/B0009XQUKW |
The Older Generation
1. Positive side of the Battery to Starter 2. Negative side of the Battery to the Block 3. Remote start button to the Positive side of the Battery and to the "S" terminal on the starter solenoid. 4. Wire from Positive side of the Battery to BAT terminal on HEI (have an alligator clip on the battery end so you can unhook it easily to kill the engine) 5. Pour a little gas in carb if fuel system is not connected 6. Oil Pressure gauge hooked up or you will coat everything around you with oil 7. You may have to close the choke to get it to start. LockDoc
Thank You Guys
![]() Join Date: Feb 2016
Good luck. Tell us how it went.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
BlahBlahBlah
Now we don't want you to post a pic of your chassis driving away by itself
You didn't mention the transmission. Don't forget to fill it with oil too.
Old member
Make sure you jack the rear wheels up in case. I just went through this with the 68. If it's not hooked up to the rear end it want matter. I had the drive shaft in. I hooked it all up just like it should be.
Last night. ![]() https://www.youtube.com/watch?v=TviYONUW5Ag
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
