04-30-2020, 08:15 PM | #1 |
Re: $1.00 60-63 C10 Cab Cuts
That's ok. If the rust isn't completely through on either side, I need both of these circled sections. I have not cut into my truck yet to see the extent of the rust, but I know it looks pretty bad from the outside, especially on the passenger side. Just to be on the safe side, if you are willing to cut out the inside section with it, that would be great. I don't need the roof skin though. Seam sealer deteriorated and let water rust out the upper lip areas.
My zip is 30188 Thanks! *Edit* I will go check on my cab in a couple minutes to see if I need the inside part or not.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-04-2020, 03:48 PM | #2 | |
Pictures |
