Old 07-11-2020, 02:05 AM   #1
Nick_R_23
Nick_R_23's Avatar
Fuel tank straps
This is probably a stupid question, but I want to double check before I waste my rivets doing it wrong.
On the fuel tank straps, one strap is longer than the other. Does the longer strap go with the taller bracket (and taller side of the tank), or the other way around?
Old 07-11-2020, 02:13 AM   #2
Jbrass58
Re: Fuel tank straps
I just dropped the left side tank on my '75. I'll check them in the morning and get back to you
Jbrass58 is offline   Reply With Quote
Old 07-11-2020, 10:35 AM   #3
Axle
Axle's Avatar
Post #34 in this thread has a good photo of a tank installed;
https://67-72chevytrucks.com/vboard/...Greenie&page=2
Axle is offline   Reply With Quote
Old 07-11-2020, 11:12 AM   #4
Nick_R_23
Nick_R_23's Avatar
Thanks, but I’m looking for the actual strap portion itself, as the replacements have two different lengths and mine were so rotten that I didn’t get to measure the old ones. The brackets are self explanatory, they can only fit on one way on each side.
Old 07-11-2020, 12:03 PM   #5
Jbrass58
Both of my factory straps measure the same - 24 1/8 inches. The threaded bolts attached to the end of the straps are the same length as well.
Old 07-11-2020, 02:13 PM   #6
Nick_R_23
Nick_R_23's Avatar
That’s weird, they’re supposed to be different lengths
Old 07-12-2020, 06:50 AM   #7
Been a while since I did mine, but from what I can remember they were same length for the straps. One thing that popped to mind, is what size tank. All my stuff were SWB trucks with the 16Gal tanks. Wonder if there is difference in the straps used on the longer tanks that came in some LWB models?
Old 07-12-2020, 07:59 AM   #8
Axle
Axle's Avatar
Well if you don't want to measure pixels ;-) you can use 1/4 bolts and mock it up...
Old 07-12-2020, 11:45 AM   #9
prairieschooner
prairieschooner's Avatar
following. Getting ready to mount the 2nd tank
Steve 1975 Chevy C10 Short Bed Fleetside
prairieschooner is offline   Reply With Quote
Old 07-12-2020, 07:07 PM   #10
Nick_R_23
Nick_R_23's Avatar
Took a chance and figured it out. Short strap goes on the short hanger (towards the front of the vehicle), and the long strap goes on the longer hanger (rear of vehicle).
Old 07-23-2020, 11:16 AM   #11
fastphin
Any pics of both tanks? We are looking to go back to dual tanks. Dropped the only one and will need everything for passenger side that is missing.
fastphin is offline   Reply With Quote
Old 07-23-2020, 12:51 PM   #12
Nick_R_23
Nick_R_23's Avatar
Check in here to see if any of these will help you, I have all the pictures I took of the tanks posted in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=806842
