Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-29-2020, 09:30 AM   #1
kglowacky
gauge circuit board
has anyone had this happen. I installed my gauge cluster and everything worked perfectly. About two weeks later when I turn on my lights my right turn signal indicator light on the dash comes on. It will stay on at any position with the lights on. If I turn it off the blinker and flashers work fine. I am assuming power is bleeding in from the lamp power from the board. Any ideas? Thanks 79 Silverado.
kglowacky is online now   Reply With Quote
Old 09-29-2020, 02:27 PM   #2
RustyPile
RustyPile's Avatar
Re: gauge circuit board
Weird problems like this usually indicate a bad/loose ground connection.. Check the ground wire connections and check the various screws providing a ground path for the circuit board..
RustyPile is offline   Reply With Quote
Old 09-29-2020, 03:35 PM   #3
kglowacky
will do good advice
Old 09-29-2020, 08:33 PM   #4
kglowacky
well removed cluster and played with the small cooper strips that connect to the plug. Got it to work but looks like a new board will be needed. Anyone recommend a brand or type or what to stay away from. Thanks
