Old 03-13-2018, 01:30 AM   #126
John H.
John H.'s Avatar
Re: Let's play name that part, bolt, harness, screw....
Your name says it all metal and wood floor adjustable brackets.
John H. is offline   Reply With Quote
Old 03-13-2018, 10:03 PM   #127
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Originally Posted by John H. View Post
Larger ones with shoulder are door lock to door screws.
Yep. Door latch to door.
Originally Posted by Curtb1971 View Post
Are the small ones are for wiper transmission to inner cowl?
The smaller versions are used to affix the lift gate strut to the lift gate on K5s.
Old 03-22-2018, 12:22 PM   #128
bob8619
Is this a fuel pressure regulator or what?
1968 C10
bob8619 is offline   Reply With Quote
Old 04-02-2018, 08:53 PM   #129
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Attachment 1766414
In line pump?
Anyone know where these seals go? I know generally but not the exact spot.
Old 04-03-2018, 01:29 AM   #130
stsalvage
Scrapper 1
stsalvage's Avatar
that Excssery bolts have so many uses.I now use them as new ground location's all over your truck makes it easier to get to and i can add more then 1 ground to the bolt.Plus if i need to use both sides in the cab i can cleans up my grounds.I have them for metric bolts and standard and fine tread.its all about making my life easier.
But the one i never see you guys showing on this whole site is the AC bracket for a 250 or a 292 Inline 6 I know nova's had them so did impala's But for the life of me never seen a chevy or GMC truck with AC with a inline 6
seen it with the 305 V6 so show me some inline 6 with AC from 1960--72.they are harder to find then the rarest GMC 1 ton short bed or the crew cab 4 door 1960--72 trucks.i've never seen any pics with the factory AC with that big A6 compressor
stsalvage is offline   Reply With Quote
Old 04-05-2018, 08:39 AM   #131
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I believe this is the correct location for these seals....
Old 06-16-2018, 10:00 AM   #132
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Ok - anyone recognize these springs? Seven inches long...
I need two more please
Old 06-16-2018, 10:16 AM   #133
SoCoC10
SoCoC10's Avatar
Parking brake cable retainer springs?
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 06-16-2018, 10:17 AM   #134
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Originally Posted by SoCoC10 View Post
Throttle return springs?
Nope. Here's a hint: two per vehicle.
Old 06-16-2018, 10:31 AM   #135
SoCoC10
SoCoC10's Avatar
I demand a recount! I changed my guess before you replied!
Old 06-16-2018, 01:03 PM   #136
bill3rail
bill3rail's Avatar
Here are a few loose connectors I found while working under the hood.
These two could be almost anything...
This one however is totally unknown to me... Initially I thought proportioning valve wire, Nope! My proportioning valve has a female plug.
Side View
This one is easy, however my truck does not use this type of connector because it has an external regulator.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 09-30-2020, 04:15 PM   #137
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
The "washers" for tail light bezel screws came up, these can work as a replacement, though you can buy #8 counter sunk washers that are close.
The package calls these ferrule washers, but I think they're really "Cup Washers" or "Neck Washers". Difference is, these are #10, the original screws are #8. No sign of a #8 replacement "cup-washer".
The length is a bit too long. I mostly ruined the first with my vise, that doesn't work, but luckily the package has five pieces So the last four were slipped onto a nail to hold it in place without ruining them, with just enough play so the washer spins freely between the vice & nail head of the nail for an easy cut with a Dremel. I cut more than I needed, Curtb1971 provided the exact measurements previous page. Can sand/polish the top rim using the nail if need be.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-02-2020, 11:30 PM   #138
71CHEVYSHORTBED402
Originally Posted by DeadheadNM View Post
In line pump?
I saw this and your later post, not a clue, never seen or heard of them.
Here guys/gals, have fun, very doable They might be a pinch hard to see, but descriptions are added for "clarity". Where are these bolts used?
Tony
Old 10-03-2020, 12:57 AM   #139
Curtb1971
Curtb1971's Avatar
I'm going to take swing and guess the top and bottom bolts are for the rag joint?
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 10-03-2020, 07:33 AM   #140
DeadheadNM
Carpe manana
DeadheadNM's Avatar
X2 rag joint.
Old 10-03-2020, 11:53 AM   #141
71CHEVYSHORTBED402
Ding ding ding. Then you know the other one too?
Tony
Old 10-03-2020, 11:56 AM   #142
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Originally Posted by 71CHEVYSHORTBED402 View Post
Ding ding ding. Then you know the other one too. Secures the rag joint to my beautiful I mean steering box
Brake booster related
Old 10-03-2020, 12:01 PM   #143
71CHEVYSHORTBED402
Darn, I already gave it away. I'm removing it now
Guess again
Pulled a front bumper of a unmolested 72 the other day and it had L8 bolts that attached the bumper brackets to the frame. Is this where your had the third option?
Just what few I've seen I'm surprised GM installed GR8 L8 bolts for a chrome bumper. Or any bumper unless HEAVY duty, but I'm no expert. Better the bolt busts then your frame I suppose, but your left hand horn will crack anyway if you strike a boulder, ask me how I know. Prior owner. Per my 71 L8 was used:
STEERING BOX BOLTS
UPPER CONTROL ARM BRACKET BOLTS - TOP These bolt on to fixed nuts like for the steering box. My truck had three original types, all GR8. One L8, One stamped with a circle, and two stamped with a dog bone.
ENGINE CROSSMEMBER TO FRAME RAIL WALL BOLTS. If memory serves me these take fixed nuts as well. So in a nutshell, if there's a fixed square nut in the frame for a 7/16" bolt you can bet it probably calls for GR8 "L8" type bolt.
On a side, I think there are many misconceptions where a GR8 should be used, GM didn't install many for good reason. I can say unless perhaps pulling a block, GR8 is out for long block components. Matter of fact someone long ago busted a GR8 on what's now a LH head, likely from doing just that. The heads came off a 68 Camaro BBC. I spent many hours drilling it out, and if not for my B/A son it would have been many more. I tapped it 7/16, though the hole isn't used.
Tony
Old 10-04-2020, 12:04 AM   #144
71CHEVYSHORTBED402
How about these. Truck takes one, I have two. One is stamped "N" like the rag joint bolts. The other is stamped "WB".
Trivia, the "N" bolts on at least my ride were special bolts, for lack of a better term. Rag joint, bed to frame carriage bolts and this.
Double F were special bolts too, you know, like the one you guys haven't figured out yet post 138?
Tony
Old 10-04-2020, 05:36 AM   #145
Redneck Rydes
Redneck Rydes's Avatar
Maybe steering shaft to column bolts
Redneck Rydes is offline   Reply With Quote
Old 10-04-2020, 10:56 AM   #146
71CHEVYSHORTBED402
Yep. I think technically the pot joint clamp but you're right there.
Speak of right there, that double F bolt somehow missed post 138 I'm going to ride this out until you guys get it
Tony
Old 10-04-2020, 11:04 PM   #147
John H.
John H.'s Avatar
The coin in the pic is the only clue for size. This maybe hard or very easy. One is orig and one NOS.
Old 10-05-2020, 12:11 AM   #148
71CHEVYSHORTBED402
I'm stumped on that grommet, looks familiar.
Where might 5/16-18 flange nuts be used?
One of these is 1/4-20, they were used with some heater hose retainers. I have two more someplace, they secure something to the dash
Tony
Old 10-05-2020, 06:22 AM   #149
HotWheelsFan
HotWheelsFan's Avatar
I see what looks like shifting arm bushings...
HotWheelsFan is offline   Reply With Quote
Old 10-05-2020, 10:48 AM   #150
John H.
John H.'s Avatar
Not shift lever auto or standard. No steering column or trans related. Probably only find on low mileage trucks. Took mine off with 25k miles. Found the NOS on EBay a couple years ago.
2 per truck
