Brake Pedal Question ?
It has been mentioned a few times on this forum, that drilling a hole 1 inch lower, where the master cylinder rod connects, provides a better angle to the firewall booster, when adding power brakes.
My question is : Is the brake pedal on a truck equipped with power brakes from the factory different than a non-power brake truck ? Is the hole lower than a non-power brake pedal ? |
#2 | |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Brake Pedal Question ?
http://67-72chevytrucks.com/vboard/s...52&postcount=9 ![]()
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 10-31-2020 at 09:35 PM. |
#3 | |
Moderator
You mean it's not unnecessary?
![]() Join Date: Jan 2011
The angle is not what gets improved its the pedal ratio and the stroke of the rod.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
60-66 Nut
The '63-'66 truck brake pedal has the hole in the same location whether the truck came with manual brakes or factory power brakes. The different ratio for the power brakes was accomplished with the bellcrank assembly on the engine side of the firewall.
I'm guessing to drill 1" lower I would measure center to center correct?
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
