Old 12-05-2020, 11:28 AM   #26
DD1
Re: Ram Horn Exhaust Manifold
Originally Posted by vince1 View Post
Just curious, what would be the reason to change them unless they are cracked or something?
Just when I needed them a set came up on kijiji for forty bucks and for the old farm truck they work just fine. My truck will always be a beater.
If they work, keep them. No reason to change that I can think of.
___________________________________________
Darien
1971 C10 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=502964
DD1 is offline   Reply With Quote
Old 12-05-2020, 05:57 PM   #27
Tom
driving is in my blood
Tom's Avatar
You don't change manifolds unless you are changing the style or the manifold failed. Ramhorns came in both 2" and 2.5" collector versions and lots of people like upgrading to the 2.5" versions.
Old 12-05-2020, 06:40 PM   #28
kenn
Hello, I am looking for a set of 2.5 manifolds. The ones on my 72 cracked (don't know the #)and I replaced them with Dorman's that have the pipe plug hole in them. I would like to get the ones without that hole but the only ones I can find are strait down and one of mine is angled towards the back. I don't really want to change my exhaust to fit the strait ones. Do they make these now that look like stock ones and where could I get a pair. Thanks K.E.N.
kenn is offline   Reply With Quote
Old 12-07-2020, 09:36 AM   #29
The Rocknrod
Moderator
The Rocknrod's Avatar
Jegs - https://www.jegs.com/i/JEGS+Performa...BoCaMcQAvD_BwE
Summit - https://www.summitracing.com/parts/s...hoCQCwQAvD_BwE
Speedway - https://www.speedwaymotors.com/Smoot...Raw,94194.html
Even eBay - https://www.ebay.com/itm/NEW-SMALL-B...4AAOSwYEBcfxd2
Old 12-08-2020, 08:51 PM   #30
mattfranklin
mattfranklin's Avatar
My shorty headers block the dipstick from working properly. So I'm looking, and these 2.5" newer ones are sure a lot cheaper than the original 'vette parts.
I want to go with more of a stock-ish look, so these are great for me. My question, though, is are these compatible with the stock-style heat shields that protect the plug boots?
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 12-09-2020, 12:08 AM   #31
kenn
Thanks but I have looked at those and they are strait dump I need the angled dump.
Old 12-09-2020, 08:55 AM   #32
The Rocknrod
Moderator
I've never seen an angled dump cast iron manifold at 2.5". If you find a set let me know I will buy it if you dont.
Old 12-10-2020, 07:27 PM   #33
AcampoDave
AcampoDave's Avatar
I want to with more of a stock-ish look, so these are great for me. My question, though, is are these compatible with the stock-style heat shields that protect the plug boots?
Pobably, Corvettes did come with heat shields.
AcampoDave is offline   Reply With Quote
Old 12-11-2020, 08:39 AM   #34
Bigdav160
Bigdav160's Avatar
Extensive ignition shielding
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 12-11-2020, 04:58 PM   #35
kenn
Thanks rod that makes my search easer, I have had the Dormans on for a little while so I could be mistaken but I thought they were 2.5s.
Old 12-17-2020, 08:04 PM   #36
Tom
Tom's Avatar
2.5's only came strait dump from the factory.
Old 12-17-2020, 09:54 PM   #37
External
External's Avatar
My manifolds leak now. 48 years old heated and reheated meatal.
I pulled the engine, rebuilt it, put it back in. I didnt think at the time they might warp.
I tried basic gaskets. Then the thick ones.. still leak. Might be cracked somewhere. I dont know. I WANT dual exhaust, so new pipes and mufflers. I just figured I'd replace the manifolds since I was there. I have the problem we all get from time to time. I purchased the black ceramic coated ones. Hoping they wont rust any time soon.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning!
External is offline   Reply With Quote
Old 12-17-2020, 10:05 PM   #38
The Rocknrod
Moderator
Those are nice, I like the coating color.
Old 12-17-2020, 10:56 PM   #39
External
External's Avatar
Hate to admit, but I got then from jegs.
Old 12-17-2020, 11:32 PM   #40
mattfranklin
Wow, those are some serious shields.
Where did you get them?
Part numbers or links?
Thanks!
Old 12-24-2020, 06:48 AM   #41
The Rocknrod
Moderator
Here are some modified manifolds to consider:
https://www.castheads.com/exhaust-ma...ust-manifolds/
Old 12-24-2020, 11:55 AM   #42
AcampoDave
AcampoDave's Avatar
I kind of did that to my own manifolds. I bought the wand extension for my Dremmel and gave a pair of stock 2" rams a port n' polish.
What he said about imported ones also rang true in my case. At one time I had purchased a pair of Chinese 2.5 straight dumps and (after they cracked), I compared them to the OEM two inchers I was replacing them with. I noticed the port openings on the imports were clearly smaller and figured they likely occluded the head offsetting any gains provided by the larger outlet. Ultimately, I used the OEM 2" ones (that I took the Dremmel to) and mated them to a mandrel bent Summit pipe kit, added performance mufflers, and I'm still happy.
Old 02-13-2021, 12:23 AM   #43
mattfranklin
I just ordered the Dorman 674-504 for the driver side on my '70 with the 350. It's to replace a shorty header that the truck came with. That shorty wouldn't let the dipstick tube fit properly and tended to burn the plug wires. I'll let you guys know how it goes.
Originally Posted by fleetsidelarry View Post
I agree with 72Freak, there's just no need for headers on mild build, daily drivers (like mine for instance). If you're going to open them up occasionally for a blast down the track, then that's a different story. I run the 2.5 rams horns. started off with an e-bay set of corvettes at about $225/set. exhaust guy broke a tab on one of the flanges and that manifold eventually cracked a couple of years later. replaced it with an after market version, basically like the Speedway one for basically that price ($80-90 ea)
p.s.: 2.5s into a 3" would be an excellent way to run, thought about that myself.
p.p.s. buy this: http://www.summitracing.com/parts/rnb-674-504/overview/ $47.97
and the matching one for the other side: http://www.summitracing.com/parts/rnb-674-503/overview/ $51.97
and you should make the $99 free shipping cutoff
