02-19-2021, 01:11 AM | #1 |
residual valve 2 front lines
02-19-2021, 01:21 AM | #2 |
Re: residual valve 2 front lines
Yup!
If you have two ports to separate lines. Your pic shows only one front port. |
02-19-2021, 06:47 AM | #3 |
You only need to use one of those front outlets. You can plug off the other and use a single line with a single residual valve followed by a T downstream to the L & R sides. Fewer junctions equal less chance of leaks.
Do you have front disc brakes? If the master cylinder is higher than the brake calipers (ie on the firewall) you don't need a front residual valve at all. Gravity does its job for you. It has two front ports. One is hidden out of sight on the bottom.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 02-19-2021 at 07:49 AM. |
02-19-2021, 09:21 AM | #4 |
hi geezer other port on bottom. miricle pie i have camaro clip with front disc brakes frame mounted booster. so master is down low.
02-19-2021, 02:09 PM | #5 |
If you run two lines from the combination valve you will need two residual valves.
02-19-2021, 02:11 PM | #6 |
thanks mr48chev just have one 2lb valve at the moment. got a 3/16 Tee and a plug just debating run 2 lines or 1?
02-20-2021, 11:15 AM | #7 |
No need to run two. One line will suffice and you don't double your workload.
02-20-2021, 04:31 PM | #8 |
getting T ready now . bending lines from master to proportioning valve now a few bends so its taking some time.
02-20-2021, 07:09 PM | #9 |
Don’t forget the need for a 10# valve for the back if you’re got drum brakes.
02-20-2021, 10:07 PM | #10 |
Thanks geezer have most of brake line stuff installed. 10lb valve installed for back
front valve Tee and lines proportional valves and master lines Last edited by 56 3100; 02-20-2021 at 10:15 PM. |
02-22-2021, 06:03 PM | #11 |
Going through the same process now. I am using my line lock for the tee. not going to be a drag car, just there to save the brake shoes while turning the tires into dust
02-23-2021, 08:58 PM | #12 |
Hey cameo linelock is a good Tee.
02-25-2021, 05:01 PM | #13 |
i think what it saved me in fittings will be eaten up in rubber replacements
