03-18-2021, 09:21 AM | #1 |
Custom glass needed
I know someone here has to have a glass cutting or custom glass company they deal with. I recently purchased a “gulp” 1990 Dodge Dakota convertible that needs some work. Most importantly I need a drivers side door glass. The glass is different than a standard Dakota and I’m not sure if the standard pickup glass just needs to be cut or if it’s completely different. I can’t find any used glass or anything available from asc who was the company that converted these trucks back then.
Hoping someone here has a contact that can help. Any one that has had custom glass made for a top chop or something?
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
03-18-2021, 10:01 AM | #2 |
Re: Custom glass needed
Give these guys a call . They can pull a pattern off the passenger side
https://www.autoglassnj.com/services...que-car-glass/
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 03-18-2021 at 10:11 AM. |
03-18-2021, 11:51 AM | #3 |
Could asc tell you if it was a cutdown stock glass?...if so, a good glass shop could fix you up
03-18-2021, 12:20 PM | #4 |
ASC closed in 2017 . I used to install a lot of ASC conversion convertible tops in the 90's
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-18-2021, 12:28 PM | #5 |
Unfortunately, I'm no help on the source of the glass, but I do love seeing the vert Dakotas. If a tree were to crush the cab on my 95 Dakota, I would consider converting it into a convertible
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
03-18-2021, 05:53 PM | #6 |
R.I.P. E.S.L.L.
I had a 1990 Dakota convertible too. I liked it but some of the convertible related parts were a problem to find.
1971 Custom C/20 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
03-18-2021, 09:08 PM | #7 |
There is a convertible cab on Facebook marketplace in either PA or NJ. Just saying.
03-18-2021, 09:09 PM | #8 | |
03-18-2021, 09:09 PM | #9 |
I’m finding that out the hard way.
03-19-2021, 08:47 AM | #10 |
R.I.P. E.S.L.L.
I feel your pain. Try finding parts for a 1950 Packard coupe.
I went to the website that Grumpy posted to order some new side windows because mine are crispy critters. They told me that they don't service my area. Oh well. Back to square one.
03-19-2021, 09:34 AM | #11 |
I sent an email last night. I will update after I get a response. Hopefully today.
03-19-2021, 11:46 AM | #12 |
Just Google " custom auto glass " in what ever area you live in .
03-20-2021, 12:50 AM | #13 |
Don't tempt me with a good time! For some reason, my parents let me park my Dakota in the garage when I came back to college back in January. I convinced them it fit better because it was shorter than the minivan. No risk of a tree branch, but I hope nothing happens to the house on top of it!
03-20-2021, 04:12 PM | #14 |
Being a side window, the stock glass would have been tempered. Once glass is tempered, it can't be cut, unless it is annealed first (about 1,000 degrees) and then retempered after cutting.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
04-16-2021, 09:10 AM | #15 |
No luck with a response. I emailed them first then followed up with two phone calls where they took my vehicle info and said they would contact me but no response.
I have since tried a couple of local glass shops to no avail. Anyone have a glass shop they have used recently? I am willing to take the other side glass out and send it or deliver it to make a template.
04-16-2021, 09:24 AM | #16 |
Moderator
Have you called Auto City Glass? https://www.autocityclassic.com/index.php?p=home
05-07-2021, 08:30 AM | #17 |
So I’ve tried everything suggested and all the local glass companies I can find and no luck. I found a glass broker and put a request out to them and there response was “at least $1000”. I responded with do you have a lead on the glass or a timeframe to find it and the response I got was “the quote is good”. Not feeling real comfortable about giving these guys a credit card number.
05-07-2021, 10:07 AM | #18 |
Like I posted a while back I used to install a lot of the ASC convertible tops on Camaro's , fire chickens , buick regals , caddy seville , dodge dakotas , I don't remember any of them having special door glass installed but rather the convertible top was designed and built to use the stock door glass . I remember you had to be careful ordering the tops on the Camaros because there was a difference in the width over the doors between year models . Can you post a few pics of the door glass with the top up and down ?
05-07-2021, 12:34 PM | #19 |
If you take some measurements of the glass, I can compare it to my 95 this weekend
05-07-2021, 01:25 PM | #20 |
Does this look like your pass side ? .
https://glassrack.net/diyfrdogldrs925.html Here is a dakota forum https://www.customdakotas.com/thread...vertible.9586/
05-07-2021, 01:43 PM | #21 |
For some reason when asc made these trucks into convertibles they made them with a vent window. I have not taken the doors apart yet but the forward edge of the glass is straight.
05-07-2021, 07:54 PM | #22 | |
It looks like the convertible had the door frames cut off, much like our Blazers. Without that rear edge to guide the glass, they would have had to have something custom-made. It's likely become a unicorn, and the only way you'll find it if I'm correct is if you can find a used one somewhere.
05-14-2021, 07:10 PM | #23 |
This junkyard in dallas shows to have one. stock #S3078
214-375-6002 https://garlandautorecyclers.com/ Make sure its a convertable though, might be listed wrong.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
05-15-2021, 07:22 AM | #24 |
Thanks for the heads up! I emailed them last night hoping they would see it in the am but the contact link must be bad. I am going to call as soon as they open. Fingers crossed!
05-15-2021, 02:29 PM | #25 |
I don’t know if I missed it but when I called I got a recording that says they are a pick and pull yard that does not check availability of parts and you have to search online to see what vehicles they have. I didn’t see any 89-91 dakotas listed and couldn’t find a spot to enter a stock number. Thanks for trying but looks like I struck out again.
