Old 09-13-2015, 01:46 AM   #26
CastIron
CastIron's Avatar
Re: Pump to Carburetor Fuel Lines, what are you all using?
So I think I'm going to run a 5/16" steel line with inverted flares from the fuel pump to an adapter to change to AN -6, then into a swivel coupler and onto an Edelbrock fuel line/filter. I don't like to use that many joints, but I can't seem to find a fuel filter that uses 5/16" fuel line (inverted flare) on both sides. Most aftermarket filters are AN -6 or for rubber hoses. I'm trying to avoid the use of any rubber between the pump and carb.
CastIron is offline   Reply With Quote
Old 09-13-2015, 01:50 AM   #27
CastIron
CastIron's Avatar
Originally Posted by MikeB View Post
So, you don't have a rubber fuel line at pump inlet? And looking at my setup, what would cause "massive fire"?
I'm guessing the potential for "massive fire" is because if a hose leaks above the engine it could pool in the intake manifold and potentially be ignited by a spark inside the distributor cap. I've seen it happen. Luckily, the hood was open and we were able to put it out immediately.
The hose by the fuel pump would most likely leak away from the engine.
Old 09-13-2015, 07:43 AM   #28
cdowns
cdowns's Avatar
rubber line is b4the pump and not pressurized on the other hand you have it after the pump and know it alls like you are standing helplessly on the side of the road waitin for a firetruck to save their dumbasses
Old 09-13-2015, 08:23 AM   #29
dirtyjim
dirtyjim's Avatar
and your nice metal line can fatigue over time and snap at the fitting burning the truck to the ground. its rare, just like your truck burning from a rubber hose failing.
just spend $20 on a fire extinguisher that should already be in every vehicle you own and put what ever hose you want on your truck.
I use hardline on mine, easy to bend and easy to flare when you have a nice eastwood turret flaring tool like I have
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 09-13-2015, 10:28 AM   #30
cdowns
cdowns's Avatar
I have never seen or heard of metal line fatigue and causing a fire but have seen hundreds of examples of lazyman rubber causeing the burn to the ground sceniero// a $20 fire exyinguisher is a clowns bet
Old 09-13-2015, 01:21 PM   #31
dirtyjim
dirtyjim's Avatar
I've seen several fires from metal lines snapping at the fitting, mostly on construction equipment, but also on a couple of passenger vehicles. I've seen at least 50 lines snap in the last 20 years on construction sites, its usually hydraulic lines but its still flammable.
many metals work harden and can snap at the fitting due to vibration.
the fuel leaks I've seen firsthand were mostly from a gasket, the clamp or fitting and not the fuel line itself.
Old 09-13-2015, 01:39 PM   #32
Cape Codder
Cape Codder's Avatar
The fuel pump moves with the engine,and carb so a solid line doesn't flex. If you have enough vibration to cause fatigue you have other problems. You will not find any factory installs using rubber lines under pressure. Even in the new pump in tank applications they use plastic lines where flex is needed.
Cape Codder is offline   Reply With Quote
Old 09-13-2015, 03:32 PM   #33
cdowns
cdowns's Avatar
how about them leaky lines on the space shuttles ya seen them too?
Old 09-13-2015, 03:44 PM   #34
dirtyjim
dirtyjim's Avatar
it shouldn't flex, that doesn't mean it doesn't flex. harmonics cause vibration too and that is usually the cause. I've seen it plenty of times, it can usually be cured by rearranging the clamps or hold downs.
Old 09-13-2015, 03:50 PM   #35
dirtyjim
dirtyjim's Avatar
i didn't get the chance to work on the shuttle any of the times I was at nasa, although a couple times when work I did work at the Sonny Carter training facility I was required to have an armed escort.
Old 09-13-2015, 09:34 PM   #36
englands 71
englands 71's Avatar
rubber lines or steel lines , Dirty Jim is right . You should all have a fire extinguisher behind the seat of all your classics. Fuel lines aren't the only cause of a fire . Electrical fires , gas fires , oil fires , keep an extinguisher on board.
englands 71 is offline   Reply With Quote
Old 09-14-2015, 09:06 PM   #37
MikeB
MikeB's Avatar
So anyone who disagrees with you is a dumbass, huh? They say name calling is the last refuge of the out-argued.
Yeah, that 4-5 psi is gonna blow a hole right through my 250 psi hose.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-06-2021, 07:52 PM   #38
Hupper7
New Member
Originally Posted by chiefcfd View Post
I recently got an edelbrbock fuel line kit with a braided hose, but the 90 degree adapter to the fuel pump doesn’t fit the fuel pump.
It is stock fuel pump on my 1970 c20
Any ideas on what the thread and size for this is?
Hupper7 is offline   Reply With Quote
Old 12-06-2021, 08:32 PM   #39
toolboxchev
Originally Posted by hamjet View Post
Its just a mild 300 HP daily driver, but its different, Thanks guys.
I must say that is some work well done sir. I have been admiring your work for years on this site.
toolboxchev is offline   Reply With Quote
Old 12-06-2021, 09:35 PM   #40
sfont66
sfont66's Avatar
I had the same line kit a few years back, my pump needed this 90 to adapt the pump to the line kit, your pump may be the same.
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is online now   Reply With Quote
Old 12-06-2021, 11:59 PM   #41
Hupper7
New Member
Yes!
That’s what I was thinking but wasn’t sure of the
Thread and didn’t want to pull it again .
Thanks!
