Old 05-03-2023, 03:01 PM   #1
61K10
61K10's Avatar
2000 silverado fuel pressure
what is the pressure at key on and idle. I have 45lbs does not go up with rpm. 5.3 eng.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-03-2023, 09:38 PM   #2
EVRLET
EVRLET's Avatar
Re: 2000 silverado fuel pressure
Key on, 2 second prime = 55-62 psi
Key off, 10 minute bleed off = 5 psi or less
You have a weak pump. Replace with GM only or you’ll be doing the repair again in a few months
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 05-05-2023, 02:28 PM   #3
61K10
61K10's Avatar
would this low pressure cause a miss fire?
1961 chevy K10
Old 05-05-2023, 09:18 PM   #4
LS short box
As said above 58-60 psi no matter what the rpm. It's an electric pump not like a small block mechanical fuel pump.
Low fuel pressure could very well cause a miss fire. Any codes via the check engine light?
Old 05-06-2023, 01:03 PM   #5
truckdude239
truckdude239's Avatar
it could have a bad fuel pressure regulator on the fuel rail also
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-06-2023, 04:48 PM   #6
61K10
61K10's Avatar
changed the reg with a new ac delco one no change. also have a 0300 code idles rough. have a new delfi pump i guess its time off with the bed.
1961 chevy K10
Old 05-06-2023, 07:18 PM   #7
hatzie
Moderator
hatzie's Avatar
Off with the bed or down with the tank. It's personal preference. I prefer lifting the bed off. If I had a lift I'd pull the tank down.
The Delphi pump is indeed the one to buy. Aftermarket pumps tend to fail shortly.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-28-2023, 04:55 PM   #8
61K10
61K10's Avatar
changed fuel pump no change of fuel pressure still 45# have not changed fuel filter tried but couldn't get the lines out after u-screwing them. will take it to a shop tired of laying under the tk.
1961 chevy K10
Old 06-28-2023, 05:22 PM   #9
hatzie
Moderator
hatzie's Avatar
Watch all 8 misfire counters and look for cylinders that seem worse than the others.
The cylinder(s) that is or are consistently slightly worse may have leaking injector(s)
Old 06-29-2023, 04:45 PM   #10
61K10
61K10's Avatar
you could be right. my scanner won't do that. miss at idle after a warm up rev it up to 2k and it's smooth running. also won't hold pressure more than a few minutes. Need to have somebody to scope it for me.
1961 chevy K10
