12-07-2023, 07:44 PM | #1 |
power steering head seal replacement now has slack.
My power steering box was leaking , so I decided to replace all the seals. Got air out once I put it back on the truck. Everything seamed to be working great. I backed it back into shop and left it for a month. Now it has 1/4 turn of slack, I checked fluid, its full. Turned the set screw 1/4 turn on steering box , no change. All I did was replace seals, it didn't have slack before I replaced seals. Any ideas what I did wrong?
12-08-2023, 02:27 AM | #2 |
Re: power steering head seal replacement now has slack.
Sorry, I don't know what a "power steering head seal" is (nor does the internet) but I'd ask what exactly was taken apart to replace it?
12-08-2023, 11:28 AM | #3 |
12-13-2023, 09:08 AM | #4 |
did you unscrew the input seal area at all? thats what sets the internal backlash on the piston assembly. the top nut only sets the lash between the pinion and piston teeth.
theres a large metal nut on the outside of the input shaft area, you can loosen it, and turn the internal part tight and back off 1/4" and lock it back in place and that will take up the slack.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
12-13-2023, 08:33 PM | #5 |
Thanks V30, yes I did unscrew input nut, Thats where it was leaking. I called myself counting the threads as I disassembled, I will take your advice and try to tighten it up some. It seems like that will do what I need.
12-18-2023, 08:59 PM | #6 | |
12-19-2023, 04:27 PM | #7 |
nice!
