Old 12-04-2009, 04:34 PM   #351
BlueJeep
BlueJeep's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Originally Posted by Frizzle Fry View Post
I don't seem to get shrinkage from grinding. Maybe I use less pressure. I have been taking the welds down to near-surface level with a grinding wheel, then hitting them with the flap disc, then 80 grit DA.
The key to avoiding warpage starts with the weld itself. On thin stuff I tac-tac-tac, jumping around to avoid too much heat in one area. It ends up looking like the steering column pass-through pic in my previous post before grinding. Not the prettiest to look at but it all gets ground smooth anyway.
I believe my warpage likely comes from the welding, as there was very little heat generated by my grinding technique.
I've recenty purchased the ebfabman videos, and tried to use what I saw there. That was, tacks all around about 1" or so apart, then tac, tac, tac...but next to each other not jumping around. I'll try more of the jumping around, is that what you did when creating the tahoe? I'm assuming that since you didn't mention it, you don't hammer and dolly the welds during or after.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-04-2009, 06:48 PM   #352
woodwright
Enjoying left field
woodwright's Avatar
I do it the same way. I tack it all around about an inch apart, and then fill in the rest with little tacks alternating around. When I shortened my long bed down to a shortbed it warped the hell out of it.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 12-05-2009, 01:27 AM   #353
Frizzle Fry
Frizzle Fry's Avatar
I only hammer/dolly as needed, which is rare. Yes this is the same thing I did on the Tahoe.
Woodwright, I'm assuming you switched to this method after getting poor results? And have you seen an improvement?
Frizzle Fry is offline   Reply With Quote
Old 12-05-2009, 02:08 AM   #354
woodwright
Enjoying left field
woodwright's Avatar
This is the way I have always done it. I wonder if my welding skills or my welders might be part of it. My mig is a small flux-core lincoln with a wire speed knob and 4 settings instead of an amperage knob. On one setting it doesn't have enough penetration, but on the next setting it blows through. My tig is a squarewave 175 thats about 12 years old. It doesn't have alot of hours, but I think it might need adjusted. I probably could practice more too.
The worst place it happened was when I welded up my side marker lights. It actually buckled the panel in a few spots.
Clint
Old 12-05-2009, 03:15 PM   #355
ERASER5
ERASER5's Avatar
Flux Core may be the problem. SMAW will give you better results. With the proper choice of wire, the welds will be easier to grind.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-06-2009, 04:29 AM   #356
38chevyhotrod
38chevyhotrod's Avatar
Frizzle, what thickness of wire do you use for the sheet metal. And what thickness do you use on the frame work. Maybe that makes the difference.
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 12-06-2009, 06:09 PM   #357
Frizzle Fry
It does make a difference. And with flux core you can only go down to .030. I use .023 on sheet and .035 to .045 on plate.
Old 12-06-2009, 07:58 PM   #358
Jvsapp
Jvsapp's Avatar
so back to the build.... any updates from your paper cutouts?
Jvsapp is offline   Reply With Quote
Old 12-07-2009, 04:58 PM   #359
Frizzle Fry
I've made the plates but first I need to patch up the inner fender while I have access. I made a single piece with a compound curve and stretched flange to fit the front side of the shock tower/fender area. It worked out really nicely. Pics to come.
Old 12-11-2009, 03:05 PM   #360
Frizzle Fry
Still needs some clean-up/finishing work on some of the welds (need a new die grinder...) But here's how it sits now.
From this:
To this:
Old 12-11-2009, 03:25 PM   #361
6772owner
Gearhead
6772owner's Avatar
That is just amazing work FF, cant wait to see the engine sitting in the 'rails again.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 12-11-2009, 03:35 PM   #362
38chevyhotrod
This is way to nice, damn this looks good.
Old 12-11-2009, 06:40 PM   #363
VA72C10
VA72C10
VA72C10's Avatar
Very nice work as usual...the best thing is you've taken the time to engineer it so that it is functional, safe, performs well, and still looks like it could have been a factory concept engine.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-14-2009, 10:08 AM   #364
BTCHN 1963
BTCHN 1963's Avatar
Boy between you and Allen's classics who needs TV! Beautiful work as always!
BTCHN 1963 is offline   Reply With Quote
Old 12-14-2009, 10:16 AM   #365
OLDIRON69
Originally Posted by va72c10 View Post
very nice work as usual...the best thing is you've taken the time to engineer it so that it is functional, safe, performs well, and still looks like it could have been a factory concept engine.
x2!
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 12-14-2009, 10:16 AM   #366
hgs_notes
GEARHEAD
hgs_notes's Avatar
In that 2nd pic there was a bolt head that is now covered over. Is there other access for it or does it matter?
Looks very nice, the welds blended in like it was stamped out plate.
hgs_notes is offline   Reply With Quote
Old 12-14-2009, 02:19 PM   #367
Frizzle Fry
Thanks everyone
That bolt is for the upper control arm and is accessible from the other side.
I've been getting some added motivation to get this thing done by watching f20c swap vids on youtube. Check out the revs on this one:
Old 12-14-2009, 02:32 PM   #368
6772owner
Gearhead
6772owner's Avatar
That is just silly cool, cant wait to hear it fire up in your ride!
Old 12-14-2009, 02:38 PM   #369
my67chevytruck
Under Construction
my67chevytruck's Avatar
great progress Mike!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 12-14-2009, 06:08 PM   #370
ERASER5
ERASER5's Avatar
Ya just gota love a 240Z! The F20C look right at home there.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 12-14-2009, 06:20 PM   #371
dammitmitchell
the pollock
dammitmitchell's Avatar
that's damnned sexy.. yers is gonna be way cooler
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 12-15-2009, 11:23 PM   #372
Sven
Sven's Avatar
Just signed up so I could post and subscribe! What a simply wicked project you have on your hands ... and so well executed.
I know how much work it is, I have a 1972 Celica I'm transplanting a complete suspension and drivetrain into from a Mazda Miata with plans to turbo the motor &/or replace it with something a little more exciting later, like a SR20DET or a F20C.
I think mine will be easier than yours because the Miata suspension, steering rack, diff, and engine all attach to a front cross member and a rear sub frame which should be comparatively less hassle to chop/fab on the car body so they can bolt up. Plus I'm starting with a somewhat larger car, so I shouldn't have as much sheet metal grafting to do. I'm sure there'll be other challenges I haven't thought of though.
I will have a similar (albeit, not as extreme) challenge to you in that the track of the Miata is 5" wider than the Celica, but I think I can lose that with some fender widening (&/or flares) and wheel offsets. I'm going to try and avoid replacing the front and rear inner fenders with tubs, but I intend the final ride height to be pretty dang low and run some big meats, so I might not be able to get away with it. I want to stick with the OEM Mazda suspension and steering geometry as much as I can, at least at first, because I'm sure they're better at suspension design than I am.
My basic plan is to project the wheel hub center lines and a front to back center line on the car which will provide me with 'cross hairs' front and rear. If I do the same on the cross member and subframe I should be able to line them up fore and aft and side to side so the wheel placement matches the fenders.
Then I am just left with working out the height of the sub frame and cross member. When I get the sub frame and cross member located I will temporarily fix it so I can get a sense for the ride height and what I need to hang the sub frame and cross member where it needs to be. Make sense?
Keep it up, mate!
-Steve
Sven is offline   Reply With Quote
Old 12-15-2009, 11:34 PM   #373
Jvsapp
Jvsapp's Avatar
aww bandwidth exceed again and i didn't get an update on the 11th guess i'll just have to wait till the end of the month.
Old 12-15-2009, 11:58 PM   #374
Frizzle Fry
Thanks for the post Steve. I love those 1st gen Celicas! I want to see one with widened fenders as opposed to the common flares you see on them.
Your project is plenty ambitious and will be an awesome combo when done. I will have IRS envy Please feel free to post a link to your build thread if you have one. I'm sure I'm not the only one here who would be interested.
As for the PB bandwitdh; try this (scroll through the thumbs on the left): http://s6.photobucket.com/albums/y23...910Large-1.jpg
Old 12-16-2009, 12:13 AM   #375
Sven
Sven's Avatar
Well, in that case ... dig the sig!
Mah Projek
Envy? Come on, man, you're sticking a F20C into a Sunbeam Minx ... I think it'll be me that's going to be green ...
It'd be easy to glue on some fiberglass flares ... I want to have a go, when the time comes, at widening them the hard way by slitting the fenders and welding in some fillets. Nothing crazy, mind, I'd like it to be pretty subtle about it but someone who knew Gen 1 Celicas would know ... One of the nice parts about the Celica is the fenders bolt on and are pretty much a single skin where the fillets would go so I *might* be able to get them into an English wheel and make a really nice job of smoothing the modifications.
All pretty ambitious stuff and I'm not doing any of that until I've proven to myself I can get the suspension to work and the motor, trans and rear end in. The car cost me $500 (you'll see why from my thread), I paid about $750 for the motor and trans and the Miata suspension/rear end bits were free so I'm into it nothing I can't recoup if I make a cats ass out of it.
Now I need to stop procrastinating and get my arse to do some work ...
-Steve
1969 Chevrolet 4x4 C10 Pickup
