Old 06-21-2007, 01:24 PM   #26
M van Run
M van Run's Avatar
Re: My 4-link install
Looking GOOD!!!!
I,m going to look this weekend for a airride set.
Greetz from Holland.
M van Run is offline   Reply With Quote
Old 06-21-2007, 01:40 PM   #27
FlatBrokeRacing
FlatBrokeRacing's Avatar
Nice truck man.
Very nice, very clean.
FlatBrokeRacing is offline   Reply With Quote
Old 06-21-2007, 03:15 PM   #28
CAL 58 GMC
CAL 58 GMC's Avatar
Originally Posted by entourageguy View Post
Checked all around locally and could not find anything over 1.25". Just bought a pair of ebay that are 2.5".Not hub centric but have access to a lathe to make the small ring.
Brian ..
Those are just like the one's I bought. I had to use 3 inch though.
CAL 58 GMC is offline   Reply With Quote
Old 06-23-2007, 01:04 AM   #29
ranover
That thing is cool I did the same thing to my 57 gmc but without bags four link is the way
ranover is offline   Reply With Quote
Old 06-23-2007, 01:04 PM   #30
55dude
55dude's Avatar
cool ride! speaking of ride how different is the ride from the leafs? post the difference good and bad. thanks.
55dude is offline   Reply With Quote
Old 06-24-2007, 03:38 PM   #31
Daniel U
Daniel U's Avatar
I'll be running leaf springs as well and would like to know the difference, as I'm no suspension buff. Thanks
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 06-24-2007, 04:36 PM   #32
watahyahknow
watahyahknow's Avatar
the 4 link the rear will make the car feel more controllable in corners cause it wont be shifting like the stock setup with leafsprings would do without the links .
you can dail in a 4 link to plant the tires harder during accelleration if youre realy intoo the mecanics of that leafsprings coil up under extreme accelleration causing the pinion to hit the bottom of the car in some cases and make the rearend bounce
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 08-12-2007, 06:21 PM   #33
entourageguy
Yellow truck club
entourageguy's Avatar
Well I just looked and realized I never posted a finished picture of my truck. The ride is a lot better and height changes are fun to play with. Just picked up a set of shock waves for the front so I guess thats a next project. Also I"m going to have to tub the rear as the calipers touch the box when lowered.
That will allow a bigger tire for the rear as well.
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 08-13-2007, 01:05 AM   #34
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Brian,
I was looking at the four link with the bags, can you tell me what type of brackets those are for the bags? Did it come with the kit or did you get them seperately,
Tri5
Tri5Nerd is offline   Reply With Quote
Old 08-13-2007, 01:37 AM   #35
watahyahknow
the yellow looks good on this truck
Old 08-13-2007, 05:24 PM   #36
entourageguy
Yellow truck club
Originally Posted by Tri5Nerd View Post
Brian,
Tri5
It was an A.R.T for 88-98 chevy truck (ars14550) all brackets came witt the kit. Lower ones were mounted in front of axle. Tops were mounted on a cross piece on frame,
Brian ..
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 08-13-2007, 09:37 PM   #37
Daniel U
Daniel U's Avatar
Very nice truck man! I envy your finished product. We don't talk to much about our '54 as your sig says it all. Being 2 times over you budget is a sore subject here at home. Congratulations on a job well done!
