Old 05-25-2007, 11:25 AM   #1
entourageguy
Yellow truck club
entourageguy's Avatar
My 4-link install
Finally getting around to posting some pics.
I picked up an ART 4-link with bags for 88-98chev pickup off ebay. I had to shorten the bars an inch and made up some plates to mount to the frame. Did a C-notch and made up some boxing plates as well. The axle is only 2 5/8" dia and the kit is for a 3" axle so I cut up a 3" piece of tubing to make up the difference when attaching to the axle. I've got rebuilt calipers and turned rotors. The parking brake cables are from a late 80s vette and are a good length for the stock mounting spot.
I've got the lower airbag mounts on the axle just need the upper mounts as well as the shock and panhard mounted. Then mount the 3 gal. tank and valves.
Anyone need a set of 5" lowering leaf springs and a truck 12 bolt
I started when the weather was still cold and pretty quiet at work. So I want to get this done but don't want to rush it.
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 05-25-2007, 02:55 PM   #2
M van Run
M van Run's Avatar
Re: My 4-link install
Hello,thats looking good!!!
Wen I have the time,I want to make it the same way.
Keep up the good work.
Greetz Mark (from Holland)
M van Run is offline   Reply With Quote
Old 05-25-2007, 04:28 PM   #3
watahyahknow
watahyahknow's Avatar
hey ook een hollander ......
i would like to see a side pic when the truck is back on its wheels with the bed mounted and the bags deflated .
i'm in the process of bagging mine and like to see how mush the mini C notch you put in the frame lowers the truck totally
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 05-25-2007, 09:53 PM   #4
entourageguy
Yellow truck club
This is how its sat before
This was with the axle approx. 3" from the factory bump stops.
The ride height when finished should be about the spot where the axle touches the bump stops. With the bags deflated the rear end just about touches the bed floor...
The P.O had the front coil overs turned up about 1.5". so that should drop the front a bit more as well
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 05-25-2007, 10:05 PM   #5
tiggerstoy
tiggerstoy
tiggerstoy's Avatar
that looks like it will hug the floor nicely....he,he,he.....low is good!
nice jod.
tiggerstoy is offline   Reply With Quote
Old 06-01-2007, 06:36 PM   #6
entourageguy
Yellow truck club
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 06-02-2007, 10:56 AM   #7
Kabwe
Certified Car Nut
Kabwe's Avatar
What is the width of your rearend (mounting point to mouning point)? By the way, nice truck .
Kabwe is offline   Reply With Quote
Old 06-02-2007, 02:48 PM   #8
Jebb1978
Jebb1978's Avatar
You did it! Great job man, it looks sweet!
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 06-02-2007, 06:52 PM   #9
entourageguy
Yellow truck club
Kabwe
I believe 60" for the 4x4 rear end
58" for the 2x4.. that is what Cal has in his.
Thanks Jebb... Where have you been lately?
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 06-03-2007, 01:55 PM   #10
CAL 58 GMC
CAL 58 GMC's Avatar
Great Job Brian! Are you running a mustang II front? are you going to run bags up front? Your trucks going to look sick when she slammed!
CAL 58 GMC is offline   Reply With Quote
Old 06-03-2007, 05:41 PM   #11
entourageguy
Yellow truck club
Yea It has a MII front end. I've been watching shock waves on ebay but have not made a purchase yet. The PO had the coil overs cranked up so I put them back down. He also notched the frame to raise it for the MII front end so the front end sits higher as well. Seems silly as he also had lowering spindles in it but felt it was going to sit too low
Picked up a set of ralley wheels to paint yellow and try out the porta whites.
Been busy this week so I haven't had a chance to do any more work on her and it's starting to drive me crazy as alot of the other people in the area have their rides out.
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 06-10-2007, 07:58 PM   #12
entourageguy
Yellow truck club
Well started blasting my ralley rims. Found some neat hot rod trim rings that will show some of the yellow paint on the rims before the white walls start. The trim rings have about 4 rings on the inner edge. Also found a set of center caps with ribs that fit where the factory top hat centers go.
Finished all the welding and put on a coat of paint. Just need to plumb the brakes and hook up the parking brake cables. Also need to mount the tank and compressor.
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 06-10-2007, 10:19 PM   #13
Daniel U
Daniel U's Avatar
Nice work Brian. Not to highjack your thread, but I just saw these this last weekend and fell in love with them:
I think I'll end up running these with a white wall untill I get some money saved back up:
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 06-11-2007, 07:23 AM   #14
entourageguy
Yellow truck club
Yea same style of rim. GM had them in a lot af sizes 14x7 15x6 15x7 15x8. Now being reproduced. Different centers are also available as well. Lots around at the flea markets too.
Hey Daniel how do you do the script between pics? is it with the : at the end of sentences?
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 06-11-2007, 01:07 PM   #15
Daniel U
Daniel U's Avatar
Brian ...
I use photobucket and after I copy the link I hit enter for a new space, and then type my message, new pic link, enter, message, etc.
Old 06-11-2007, 07:33 PM   #16
Jebb1978
Jebb1978's Avatar
Brian ...
Here and there, I check in just normally don't post. I am ashamed of my lack of progress. I worked on it this weekend, didn't get much done but I was out there pluggin away.
1959 GMC project
Old 06-18-2007, 11:18 PM   #17
entourageguy
Yellow truck club
Well I reworked the panhard bar and got the rims on today. Mounted the air tank and compressor. Bled the brakes and hooked up the parking brake. Installed the rear tires put it on the ground and went for a drive. When I got back I thought I'd better try the box on for clearance for the brackets on the steps. Have to cut out a small notch to clear the 4 link front brackets. Also found out you can't put a box that is 51" wide between two rear tires that are only 49.5" spacing. So I'll be checking out some spacers tomorrow. Here are a few more pictures...
Brian ....
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 06-19-2007, 02:28 AM   #18
Daniel U
Daniel U's Avatar
I likey, I likey. I'd really like to see a shot of the front end too. What center caps are you going to run? Looking good Brian. Keep it up.
Old 06-19-2007, 08:15 AM   #19
entourageguy
Yellow truck club
I'm using a small center cap that I found on ebay:
Here's a front shot for you Daniel.
I'm happy with the porta whites. They sit flush with the tire.
Brian
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 06-19-2007, 09:10 AM   #20
Lightning
Lightning's Avatar
nice progress, that truck is sweet!
1948 Chevy 3/4
Lightning is offline   Reply With Quote
Old 06-19-2007, 10:24 AM   #21
Daniel U
Daniel U's Avatar
Very clean! Did the PO have the fuel tank inside the cab?
Old 06-19-2007, 10:47 AM   #22
entourageguy
Yellow truck club
Yea I moved it to the rear last year.
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 06-19-2007, 09:18 PM   #23
dwcsr
Hollister Road Co.
dwcsr's Avatar
it really looking good. I like the wheels and tires. Nice touch.
dwcsr is offline   Reply With Quote
Old 06-21-2007, 12:26 AM   #24
CAL 58 GMC
CAL 58 GMC's Avatar
Man that look's SWEET, entourageguy! She sitting nice and low, just the way I like them! How large of spacers will you have to use?
Old 06-21-2007, 07:34 AM   #25
entourageguy
Yellow truck club
Checked all around locally and could not find anything over 1.25". Just bought a pair of ebay that are 2.5".Not hub centric but I have access to a lathe to make the small ring.
Brian ..
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
