#26 |
Re: Making a trailer from a Pickup
I have built hundreds of these trailers. I personally use a 3/4 ton with coil springs with a hydraulic dumping bed. I have hauled 5000lbs of gravel in it. With a coil spring trailer, you need to have good shocks or it will sway all over the road. For best performance, cut your axle shafts off and bolt the end plates back on. Next, remove your dana 60 3rd member and weld a plate to cover the opening. Add gear oil to keep your hubs lubed. You now have a full floating straight axle. With an eaton axle, you can simply buy an additional pumkin cover and use that to cover the opening instead of having to weld a plate. You can also sell the eaton 3rd member for $100- $150 which will cover all costs to construct the trailer.
#27 | |
Vintage 4x4s
No brakes won't be an issue when pulling this with the 2500hd but I will be pulling this on occasion with my honda Pilot and lets face it, its not a real truck and could benefit from brakes, especially with the traffic in the minneapolis area. This trailer has new brake lines and non rusty parts. I bolted on a standard coupler for now and will see how she works before buying a hydraulic actuator.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#28 | |
Vintage 4x4s
Got the wiring hooked up. Sure is easy to use the original lights and they are nice! Now if I could incoorporate the backup lights that would be awesome. Also tempted to hook up a hand parking brake on the tongue and use the parking brake feature too. I know some will say don't bother but why not if they are in good shape and stay that way since I won't use this in the winter and salt them up.
#29 |
The axle end plate is part of the axle shafts. I just cut the shafts right by the plate and bolt the plate back on to seal the axle housing. I remove the eaton 3rd member for the purpose of selling the parts. I guess you can leave the pinion on a dana since it does not have much value for parts. If you step up to a 7 pole connector, you can use your reverse lights. I did that on my trailer because I needed the extra wires for the hydraulic dump. A member in Grass Valley, CA uses the 67-68 parking break for his trailer. I have not bothered to because I'm on flat ground; he lives up in the mountains. There are some old threads about these trailers and he has a pic of his e brake setup.
#30 |
Vintage 4x4s
Thanks guys for the advice. I got it on the road and works great. I replaced the tailgate, rear bumper. I also redid the shocks and aired up the tires so it rides better than my standard 9' utility trailer now. The longer tongue makes it stable and ride better. Also removed the axles, redid the gaskets and put fresh gear lube in. Just need to straighten out the tailight area, mount the truck toolbox on front, and prime and paint everything. Oh, and maybe wire in the backup lights.
Got about 300 in parts it so far but Its capable of high speed cross country hauling heavy loads. Not too shabby if you ask me.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 Last edited by Vintage Windmills; 09-29-2011 at 02:06 PM. |
#31 |
BlahBlahBlah
That looks great. I don't know enough about rear ends to totally get what you did. Guess Ill look at a parts break down of one so I can figure it out.
I'd really like to know the specifics about where you did your bends, how long is that extra bar you welded in for the tongue? Just a little more detail when you have a minute.
#32 |
laying low
![]() Join Date: Mar 2001
CG here's a link to building a truck bed trailer I ran across. Looks like a solid deal to me. Of course there are a number of ways to build the tongue.
I am saving a 97 truck to do just this with.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#33 | |
![]() Join Date: Nov 2007
72 C20 Longbed 05 1500 Z71 |
#34 |
Roadtrip!
![]() Join Date: Feb 2003
Now if you would just fix those tail light and back up lenses you will be set!
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#35 | ||
Vintage 4x4s
Eric, A nice guy stopped by on Saturday and helped me pull out the dents around the tailights
![]() Quote:
![]() Quote:
I'll take some measurements on the bends and let you know. I don't know if its the best way, I just know it was pretty easy and this pulls great with no sway or hopping but I did put new shocks on also.
#36 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=438550 ![]() ![]() 1994 Buick Roadmaster 1994 GMC Sonoma |
#37 | |
Vintage 4x4s
I'm going to do the permanent wiring with some cord that runs through the rectangular tube tongue.
#38 |
Vintage 4x4s
more pics. Tape is measuring from the box bracket edge in the 1st pic below
#39 |
BlahBlahBlah
Thanks for the extra pics and info!
Mark
#40 |
Collector of Projects
I picked up one of these long bed coil spring trailers... I just registered it on Friday. The guy I bought it from overloaded it and broke the panhard bar and the spring retaining plate... I hope to fix those two isses next week. I just need to find some tires....
#41 |
SLOW POKE
![]() Join Date: Nov 2010
Fine looking trailer you made there V W . Has anybody done this with a short-stepside bed w/o the extra room for a toolbox ? Also someone mentioned a " how to " link . I would hate to cut my frame too short . Thanks !
68 ![]() piece by piece ,
day by day , I will restore this truck , before the 100th anniversary !!! ![]() |
#42 |
laying low
I think that was me. I should have gone back and put this in later. While V W's looks good there are several ways of going about it. I found this one some time back and liked it. Cannot deny it's strong.
And yes trailers have been made using short stepside beds. There is a member here with a real nice green one although i cannot remember his name at the moment. Maybe he'll see this and post it up for you. http://sweptline.com/blog/2009/01/20...-pickup-truck/
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 10-09-2011 at 11:14 AM. |
#43 |
how do you license these trailers??? i have one made out of a 1970's ford pickup and im not sure how to register and license these. I live in colorado if that makes a difference.
#44 |
Who's got steelies?
![]() Join Date: Feb 2006
Ya mean one of these?
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
#45 |
BlahBlahBlah
I know its easier to maneuver with a longer tongue, but it seems if you get it too long you are going to lose stability without enough weight on the tongue. Trailer could get pretty squirrely back there.
#46 | |
Vintage 4x4s
