12-05-2020, 11:28 AM | #26 |
Re: Ram Horn Exhaust Manifold
If they work, keep them. No reason to change that I can think of.
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 |
12-05-2020, 05:57 PM | #27 |
driving is in my blood
You don't change manifolds unless you are changing the style or the manifold failed. Ramhorns came in both 2" and 2.5" collector versions and lots of people like upgrading to the 2.5" versions.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
12-05-2020, 06:40 PM | #28 |
Hello, I am looking for a set of 2.5 manifolds. The ones on my 72 cracked (don't know the #)and I replaced them with Dorman's that have the pipe plug hole in them. I would like to get the ones without that hole but the only ones I can find are strait down and one of mine is angled towards the back. I don't really want to change my exhaust to fit the strait ones. Do they make these now that look like stock ones and where could I get a pair. Thanks K.E.N.
12-07-2020, 09:36 AM | #29 | |
Moderator
Summit - https://www.summitracing.com/parts/s...hoCQCwQAvD_BwE Speedway - https://www.speedwaymotors.com/Smoot...Raw,94194.html Even eBay - https://www.ebay.com/itm/NEW-SMALL-B...4AAOSwYEBcfxd2
12-08-2020, 08:51 PM | #30 |
My shorty headers block the dipstick from working properly. So I'm looking, and these 2.5" newer ones are sure a lot cheaper than the original 'vette parts.
I want to go with more of a stock-ish look, so these are great for me. My question, though, is are these compatible with the stock-style heat shields that protect the plug boots?
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 Last edited by mattfranklin; 01-07-2021 at 01:48 PM. |
12-09-2020, 12:08 AM | #31 |
Thanks but I have looked at those and they are strait dump I need the angled dump.
12-09-2020, 08:55 AM | #32 |
Moderator
I've never seen an angled dump cast iron manifold at 2.5". If you find a set let me know I will buy it if you dont.
12-10-2020, 07:27 PM | #33 | |
12-11-2020, 08:39 AM | #34 |
Extensive ignition shielding
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
12-11-2020, 04:58 PM | #35 |
Thanks rod that makes my search easer, I have had the Dormans on for a little while so I could be mistaken but I thought they were 2.5s.
12-17-2020, 08:04 PM | #36 |
2.5's only came strait dump from the factory.
12-17-2020, 09:54 PM | #37 |
My manifolds leak now. 48 years old heated and reheated meatal.
I pulled the engine, rebuilt it, put it back in. I didnt think at the time they might warp. I tried basic gaskets. Then the thick ones.. still leak. Might be cracked somewhere. I dont know. I WANT dual exhaust, so new pipes and mufflers. I just figured I'd replace the manifolds since I was there. I have the problem we all get from time to time. I purchased the black ceramic coated ones. Hoping they wont rust any time soon.
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning! |
12-17-2020, 10:05 PM | #38 | |
Moderator
12-17-2020, 10:56 PM | #39 |
Hate to admit, but I got then from jegs.
12-17-2020, 11:32 PM | #40 |
Wow, those are some serious shields.
Where did you get them? Part numbers or links? Thanks!
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
12-24-2020, 06:48 AM | #41 |
Moderator
Here are some modified manifolds to consider:
https://www.castheads.com/exhaust-ma...ust-manifolds/
12-24-2020, 11:55 AM | #42 | |
What he said about imported ones also rang true in my case. At one time I had purchased a pair of Chinese 2.5 straight dumps and (after they cracked), I compared them to the OEM two inchers I was replacing them with. I noticed the port openings on the imports were clearly smaller and figured they likely occluded the head offsetting any gains provided by the larger outlet. Ultimately, I used the OEM 2" ones (that I took the Dremmel to) and mated them to a mandrel bent Summit pipe kit, added performance mufflers, and I'm still happy. |
02-13-2021, 12:23 AM | #43 | |
I just ordered the Dorman 674-504 for the driver side on my '70 with the 350. It's to replace a shorty header that the truck came with. That shorty wouldn't let the dipstick tube fit properly and tended to burn the plug wires. I'll let you guys know how it goes.
