Old 03-20-2010, 04:12 AM   #476
Jvsapp
Jvsapp's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
it's all good FF. we know tubby will get some good lovin once the minx is mobile.
Jvsapp is offline   Reply With Quote
Old 03-25-2010, 05:29 AM   #477
Frizzle Fry
Frizzle Fry's Avatar
Well, I ended up scoring a bunch of polished stainless Borgeson goodies of craigslist so the fact that I borrowed parts from Tubby resulted in an upgrade for it anyway.
...back on the Minx. Here's what I've been up to.
Tacked front lateral:
Rear lateral mock:
Engine mount placement:
All welded up:
Frizzle Fry is offline   Reply With Quote
Old 03-25-2010, 05:34 AM   #478
Frizzle Fry
...other little tasks completed:
Shift rod shortened/drilled, and housing located. Just need to get it tig'ed up:
Sectioned the steering column by ~2.75" so I could mock up the steering shaft location for engine mount placement:
Old 03-25-2010, 05:44 AM   #479
Jvsapp
Jvsapp's Avatar
damn FF that subframe is beautiful. it would look nice powder coated. probably last forever too. awesome work. you still never cease to amaze us.
the shifter are you going to put a sleeve on the exposed shaft?
Old 03-25-2010, 06:59 AM   #480
nuke1
nuke1's Avatar
Nice!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-25-2010, 09:30 AM   #481
6772owner
Gearhead
6772owner's Avatar
WOW thats just incredible attention to detail, I cant get over the quality of this build, did you see those welds??
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 03-25-2010, 09:47 AM   #482
ERASER5
ERASER5's Avatar
When did you get a TIG? Did I miss that? Names, numbers, pics. I wish my welds looked halve as good. I TIG welded some stainless exhaust pipe lase night. Boy do I need practice welding out of position! I will grind it today and see what I missed.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-25-2010, 10:21 AM   #483
BlueJeep
BlueJeep's Avatar
Those are MIG welds.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-25-2010, 04:48 PM   #484
Frizzle Fry
The subframe will be powdercoated and the shift rod cover tube will be shortened and installed. I mentioned tig welding regarding the trans case, which is aluminum. I don't have a tig ...yet I still have room for improvement on the welding. Have you seen Porterbuilt's or Built-by-Brooks'??? Thanks for the compliment though.
Old 03-25-2010, 06:58 PM   #485
dammitmitchell
the pollock
dammitmitchell's Avatar
you make me envious...
grrr!
dang good work!
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 03-25-2010, 11:39 PM   #486
ERASER5
ERASER5's Avatar
Yes those steel welds are MIGs. I was referring to "Just need to get it tig'ed up". Can't TIG without a TIG. I could have separated the thoughts better though.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 03-26-2010, 02:23 AM   #487
454_72_4X4
454_72_4X4's Avatar
Good choice on the radiator FF! I just recieved a Griffin today for my Sonoma.
I'd comment on the subframe but why seperate it from everything else. ALL the work looks great!
Ya have a tubing bender or do you have somebody bend the tubing for ya? (subframe and ya mentioned bending up some a-arms in the future)
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 03-26-2010, 09:53 AM   #488
Frizzle Fry
I have a JD2 model 32. I borrowed some 1.5" model 3 dies and they wouldn't fit my bender (bigger pins on the 32) so I ended up borrowing the whole bender (hydrolic one).
Old 03-29-2010, 04:22 AM   #489
Jvsapp
Jvsapp's Avatar
i wish i had friends like FF and his friends. then maybe i could borrow tools and trucks too
Old 03-29-2010, 12:04 PM   #490
Mil-Spec
Mil-Spec's Avatar
Great work! I really look forward to seeing how well she performs
SEMPER FORTIS
U.S. NAVY 97-05
USAF 94-97
Mil-Spec is offline   Reply With Quote
Old 03-31-2010, 02:17 PM   #491
LONGSWHEEL
Awsome build. I like your out of the box thinking.
LONGSWHEEL is offline   Reply With Quote
Old 04-01-2010, 12:18 PM   #492
Frizzle Fry
Thank you. I planned to spend all day on it Tues but got called in to work. It could be worse though... No complaints
Old 04-12-2010, 05:04 AM   #493
1971c20
1971c20's Avatar
Wow, great job. It sure as come along way since last time i saw it.
1971 C20 350/350 SOLD
1976 C10 LWB 400/350
1971c20 is offline   Reply With Quote
Old 04-12-2010, 12:45 PM   #494
Frizzle Fry
Thanks man. How'd those wheels work out?
I haven't updated this in a couple weeks because I started a minor house project that snowballed like everything else I do...
I do have one motor mount ready for final welding
Old 04-12-2010, 12:50 PM   #495
watahyahknow
watahyahknow's Avatar
must have a bad case of the might-as-whell's
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 04-12-2010, 12:56 PM   #496
Frizzle Fry
Big time! The house was built in 1948 so everything about it is a might-as-well.
Old 04-12-2010, 03:32 PM   #497
watahyahknow
realy like the older houses they have a lot of details and craftmanship in them
lot of scrolls in the woodwork and in the banister of the stairs old style joints in the structure sumtimes woodpanneling and a lot of fancy plastering , they usually need a lot of work i seen a lot of buildings that where completely changed in the 70's and everything hidden behind plasterboard to give it that clean modern look they where after back then you often cant use a electric sander on those scrolls and round shapes and offten those details are painted in but i think there worth it
like to see some pics of the details in the house
Old 04-13-2010, 03:44 PM   #498
Frizzle Fry
It has nothing like that. It was basically a farm house that was expanded and remodeled over the years with very little attention to detail. Good "bones" though. Lotsa potential.
Old 04-13-2010, 05:46 PM   #499
BlueJeep
BlueJeep's Avatar
Sounds like my last house. 1947 story and 1/2, but never remodeled or expanded until I bought it. Good bones. Built a 30x36 garage, place for my car trailer, gutted the house, made everything just the way I wanted it and sold it...had twins a couple years ago and my space needs for a house changed quickly.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 04-13-2010, 07:44 PM   #500
watahyahknow
hmmm you couldve build an extention on top of the garage for the kids
i later thought about it the house is out of 1948 so shortly after the war , over here they pounded out homes by the dozen after the war was over because of the bombings lots of people needed homes and they where pretty basic to build them faster
