09-23-2011, 08:16 PM | #951 |
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
you're in!
09-23-2011, 08:21 PM | #952 |
09-28-2011, 04:39 PM | #953 |
I have finally read through this entire thread and am slowly making my way through the Tahoe thread as well..all i gotta say is SIIIIIIIIIIIICCCCKKKKK!!!!! I wish i had even a quarter of your skill when it comes to working on sheet metal!
09-28-2011, 09:39 PM | #954 |
Thanks a lot man. Glad you dig it. More progress has been made. Pics tonight...
09-28-2011, 10:55 PM | #955 |
As promised.
I took a little break from sheet metal and knocked out a couple items that had been buggin me (read ADD kicked in ...again). During mock up I had noticed that the Spohn Del-Shperes were limited in travel by one of the tapered bushings. I'm using two on each but a design element causes one side to hit before the other (see pics). Bushing at travel limit: Other side has a ~1/8" left: Solution (poor man's lathe) Result: This may not look like much here but I gained 1/2" of travel at the other end of the arms. |
09-28-2011, 10:58 PM | #956 |
67cheby
your just amazing....just sayin
09-28-2011, 11:06 PM | #957 |
Another thing that bugged me was the tight clearance between the lower arms and the xmember at one point when the alignment bolts were set to the inboard position:
Solution: The S2000 xmember sections I used were lopped off behind the rear arm mount holes in order to fit the Minx because the Minx frame rails drop down just aft of the arms. So it has been the plan, and is finally implemented, to box the ends for restored strength: Ready for powdercoat: |
09-28-2011, 11:10 PM | #958 |
09-28-2011, 11:21 PM | #959 |
So Many Ideas, So Little Money
its all just awesome, I want you to get it together for two reasons, 1. i wanna see video of this terror tearing up the streets or track. 2. I wanna see work on the tahoe!
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
09-28-2011, 11:54 PM | #960 |
Still Learning
Super progress Frizzle! Your welds and metal work set the bar so high.....gives me something to shoot for
09-29-2011, 07:21 AM | #961 |
Awesome work Frizz!
I've been lurking and admiring your builds for a while now. There is one aspect of this build that concerns me, and that is the sway bar mod. The sway bar is designed to absorb torsional forces and distribute them evenly down the length of the bar. When you cut and welded that bar to shorten it, you increased the stiffness (by decreasing the length) and I suspect that there is also a "stiff spot" in the bar at the weld point now.... So torsional forces will not be distributed evenly anymore. I don't know what the ultimate effect will be, but I suspect that you might end up with cracks at the welded area, and/or the bar will behave like a much thicker diameter one and may upset the handling. I am fairly certain that there are companies out there who can custom-bend a sway bar to match the shape you need using your modified sway bar as the template. Or you could convert to a 3-piece sway bar setup with a center torsion bar and two splined end links. That style would allow you to swap out the center bar (thicker or thinner) to fine tune the handling later on. Or change the lengths of the end links to soften or stiffen things up. Just a few thoughts over my morning coffee.... The fabrication is amazing! -G Posted via Mobile Device Posted via Mobile Device
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well™" Build |
09-29-2011, 10:24 AM | #962 | |||
Posted via Mobile Device |
09-29-2011, 11:18 AM | #963 |
now only if that lathe panned out a few weeks back.....
looks like you gained a TON of articulation there though. also looks like the subframe is just about ready for powdercoating? awesome work as usual. i can understand the whole ADD thing. small things drive me nuts too.
63 4 door Chevy II - NOVACATION (Updated 08/23/09) 65 Morris minor Traveler 77 Chevy Longbed. 93 Corolla JDM 20V Swap Daily Driver (Updated 07/16/09) Powder coating Hawaii Domestic Violence Awareness Show 5/3/09 Hawaii Rod and Custom Show 4/18 |
09-29-2011, 12:19 PM | #964 | |
09-29-2011, 08:31 PM | #965 |
taking another look at those pics..... FF man you must own stock in a grinding disc company? i see what looks like at least 4 discs on the bench/ground in that pic.
and i think i have the same hole saw mandrel!
09-30-2011, 01:53 AM | #966 | ||
Yes! Quote:
...and another arrival to the party (tintable) |
09-30-2011, 02:28 AM | #967 |
VA72C10
Nice! Where do you find the most durable flap discs and wire wheels? I've been getting the wheels from HF and they are super cheap on sale and seem to last a decent time compared to a dewalt one I had but don't know how to compare....
I've been getting the flap discs from Lehigh valley adhesives for fairly cheap but not happy with how they last....
Looking for a 67-72 swb or blazer project in or around VA. |
09-30-2011, 08:29 AM | #968 | |
The formulas for calculating sway bar stiffness are on the interwebs but as you mentioned, it's largely an academic argument....the test drive will tell you if it's too stiff or not. I don't recall if this bar is on the front or rear. If it's a rear bar, you will probably have a ton of oversteer, if it's a front bar you'll see understeer. With as much power as you are adding to that chassis, it might be good to set the car up for some understeer and when you want to kick the tail out with oversteer....just call for it with the throttle! Good stuff... Keep those pics coming! -G Posted via Mobile Device Posted via Mobile Device
09-30-2011, 08:51 AM | #969 |
GEARHEAD
Just wondering if heating the entire bar would fix the grain in the heat affected zone of the weld. Not a full heat treat, which would probably harden it more, but maybe a soak at like 5-600 F. I'm not a metalurgist, but work with ASME steel fab shops, and I stayed at a Holiday Inn Express once.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
09-30-2011, 09:49 AM | #970 |
Just started buying some of the consumables at HF. The cut-off wheels work fine. Grind disc seem ok. Flaps wear fast. Can't remember if I picked up a wire wheel there or not. Prior to that I was getting them from various places; Airgas, HD/Lowes, Fastenal, local metal shop.
It's the front bar that I've shortened. So yes, understeer will be the result of too much front anti-roll. I do have a rear bar I plan on running so that will help. Ultimately I'd like to build a front bar with blade arms: HG, I'll have to googlify that! |
09-30-2011, 11:04 AM | #971 |
GEARHEAD
Could also reduce the diameter of the bar, a good machinist should be able to figure a way to mount it in the chuck.
09-30-2011, 12:29 PM | #972 |
The blade ends provide instant adjustability. By turning them their flex rate changes which provides the equivalent of a thicker or thinner bar.
09-30-2011, 12:31 PM | #973 |
67cheby
my little brain cant even comprehend how that could possibly work....BUT WOW THAT IS COOL
09-30-2011, 02:05 PM | #974 |
X2! Dangit! No sleep tonight. This will be turning in my brain for days!
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
09-30-2011, 03:20 PM | #975 |
I'll come out right and ask for more info on the blade arms, what are the stepped levels about, how do you dial them in firmer/softer? Cool stuff as usual and thanks in advance.
