Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 12-08-2008, 04:29 AM   #1101
ERASER5
ERASER5's Avatar
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
Any pic of the clown car with the race engine in it? I know your holding back.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-08-2008, 04:29 AM   #1102
Frizzle Fry
Frizzle Fry's Avatar
Welcome to the board Smalls. Maple Valley, not too far. Tubby does need a brother Thanks for the good words It's probably a good idea to look for those hinges first if you plan to do the mod because they are a lot harder to find than a 67-72 Burb... Post a WTB (gotta subscribe first) on the 60-66 parts board if/when you are serious about finding them. Hope to see another Tahoe build thread soon!
Frizzle Fry is offline   Reply With Quote
Old 12-08-2008, 04:45 AM   #1103
Frizzle Fry
Hah, actually I bought the drivetrain on eBay and it's been hell getting the guy to ship it... It's on a truck now
but here's a couple of cell phone teasers for ya...
Old 12-08-2008, 05:00 AM   #1104
Jvsapp
Jvsapp's Avatar
OOOOHHHHHHH teaser
like the power rack conversion. what did you use?
Jvsapp is offline   Reply With Quote
Old 12-08-2008, 05:09 AM   #1105
Frizzle Fry
Actually that's the rack I bought for Tubby to go with the dropmember. So it's a MII but it's just sitting in there to check for clearances/positioning. I may use it, or go with a manual rack. Haven't decided yet. Either way I'll have to buy another rack to do both vehicles.
Old 12-08-2008, 05:35 AM   #1106
Jvsapp
Jvsapp's Avatar
cool that works. i've heard about some guys using a Tbird rack from a 80's something tbird... never looked it up though.
Old 12-08-2008, 08:13 AM   #1107
Rokcrln
Rokcrln's Avatar
Mike is the car's pivot points the same as a DropMember? Looks to be a bit narrower from the pic, now would that not cause bump steer and what not? So did you just get the motor and trans or the rear end set up as well from the S2000?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 12-08-2008, 08:12 PM   #1108
Frizzle Fry
Width has an effect on bump steer, but can be somewhat addressed via rack placement. Obviously the effect is exponential as the selected rack moves away from "perfect" width/tie rod length. Width also has an effect on ackerman angle as does fore/aft rack placement. Edit: Rack height effects bump toe. I'm also looking at a smaller/lighter manual rack out of a Midget. There's a local British auto shop that rebuilds them.
I just got the eng/trans for now. The car was painfully slow and could barely make it up a slight grade on the freeway when loaded with 5 people. Still, I was OK with keeping the factory drivetrain until I started hearing some lower-end knock. Combine that with its desire to die at stoplights, the anemic automatic trans, and I was shopping for something else to motivate it. The intention is not to go full retard on it, just to make it more reliable and fun to drive. I researched a few options including the all aluminum 3.6L 60 degree V6 from the Caddy CTS (which will also be used in the six cylinder 2010 Camaro). But I ended up going this route to minimize weight and sheet metal cutting. So for now I'm just doing the engine/trans and possibly converting the brakes from a single to double circuit system (safety). By the way, the S2000 weighs 33% more than the Minx
I'll see how long the stock rear holds up and go from there. IRS is not off the table for a future upgrade
Kevin
LFD Inc.
Old 12-09-2008, 12:37 AM   #1109
BlueJeep
BlueJeep's Avatar
Any more rack & pinion tech you can share? I always thought ackerman angle pertained to the line drawn from the tie rod hole in the knuckle, through the "center" of the ball joints, and where both of these lines intersected in relationship to the rear axle....
I believe this link is similar to what rokcrln was asking about:
http://www.heidts.com/pdf/Understanding_IFS.pdf
Thanks!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-09-2008, 05:43 AM   #1110
Frizzle Fry
That's a good link, thanks. Here's a quote I liked "the exact length and location of the inner pivot of the tie rod must be very carefully selected so the outer ends of the rod, which are attached to the spindles, swing in a radius which matches the spindle radius exactly." This means the rack width should be selected to achieve the desired tie rod length which is dermined by the spindle arc.
Here's an explanation of Ackerman angle (R/C site): http://www.rc-truckncar-tuning.com/ackerman.html You can see why moving the rack fore/aft would have an effect on it.
Old 12-09-2008, 06:28 AM   #1111
Jvsapp
Jvsapp's Avatar
i see i'm not the only one that has a background in RC car racing
Old 12-13-2008, 04:58 PM   #1112
Frizzle Fry
Alright, back to Tubby... No I don't have an update, but I do have this to share: http://www.sporttruck.com/featuredve...ban/index.html
Old 12-13-2008, 06:03 PM   #1113
abadsvt
abadsvt's Avatar
Congrats mike! So do you get totally excited everytime you read about your tahoe? I can only wait and hope that when my truck is finished i get some magazine coverage like your bad a$$ tahoe! Now stop reading this thread get back to work cause we want to see this thing finished!!!
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 01-02-2009, 03:49 AM   #1114
Jvsapp
Jvsapp's Avatar
wanted to wish u and tubby happy new year
Old 01-02-2009, 06:50 AM   #1115
Frizzle Fry
That's cool man. Thank you and back at ya! I'm really trying to hurry up with the side project so I can get back on this one. I miss it...
Old 01-02-2009, 02:29 PM   #1116
Jvsapp
Jvsapp's Avatar
feel free to post them side pix, especially if its the minx. that'll be a cool ride once done.
BTW any chance you will make the hot rod power tour this hear? i'm supposed to ride along with my bro in june and it'd be cool to see tubby in person.
Old 01-02-2009, 10:09 PM   #1117
ERASER5
ERASER5's Avatar
Frizz, about your one piece hatch,How does it lock? Or does it?
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 01-02-2009, 11:40 PM   #1118
Frizzle Fry
The power tour is in the mid west isn't it? Wish they'd do it on the west coast one year.
The hatch latches and locks with the stock tailgate latches. Too simple huh?
Old 01-02-2009, 11:52 PM   #1119
ERASER5
ERASER5's Avatar
OK. I thought that the upper lid closed over the lower gate and only the upper gate locked originally. That's what I get for thinking.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 01-03-2009, 12:07 AM   #1120
vk_chevy
vk_chevy's Avatar
mike, you got a blog or a forum for your minx doing the swap?
72 Chevy C20 Longhorn
72 Chevy, K20 Custom Camper
67 Chevy, LWB, C20, 350/350, PS, PB,
65 Jag MKII
vk_chevy is offline   Reply With Quote
Old 01-03-2009, 05:03 AM   #1121
Jvsapp
Jvsapp's Avatar
if they do west coast, then i'll have to ship one of my vehicles. either the nova or the c10. 2010 will probably start in Tenn and head either for florida or probably texas or something.
Old 01-03-2009, 05:57 AM   #1122
Frizzle Fry
Not yet. I've been taking pics as usual and looking for a good home for the build. I may start a project journal at hotrodders.com. The project is an odd-ball with no clearly defined home other than being what I would now put in the hot rod category. I'm open to any other suggestions.
Old 01-04-2009, 03:06 AM   #1123
Jvsapp
Jvsapp's Avatar
post a link if you do.
Old 01-04-2009, 06:02 PM   #1124
c10chevy69
c10chevy69's Avatar
It took me two days to read to the end of 45 pages (so far). Your imagination and skills are simply outstanding. I will continue to watch your progress until the end of this build (but they never really are finished are they?). I can only hope to have half the energy and inspiration that you do to someday finish my 69/72. Thank you for all of your hard work.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug
c10chevy69 is offline   Reply With Quote
Old 01-04-2009, 11:24 PM   #1125
robmrtnbb5
robmrtnbb5's Avatar
Just wanted to say youve got a realy kool build going on hear lookin good
bob m
bondo bob
http://s424.photobucket.com/albums/p...albumview=grid <<<link to my stuff and project 68 step side build
robmrtnbb5 is offline   Reply With Quote
