02-07-2012, 02:32 PM | #1126 |
Still Learning
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Brother you got some SKILLS! Awesome work on the lines like the crossmember fix....too bad on the P.C.
02-07-2012, 02:44 PM | #1127 |
the pollock
so what's the plan for the underbody when done?
and im jealous!. if i left all those welds unsealed like that here by the end of the day theyd have surface rust from the humidity.. (rush isnt a real issue here.. just surface rust)
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
02-07-2012, 03:24 PM | #1128 |
So Many Ideas, So Little Money
Thats what i was wondering too.... Well Friz whats the plan?
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
02-07-2012, 03:47 PM | #1129 |
Thanks dudes. I have some tintable Raptor Liner for the underside. Will be body color.
Posted via Mobile Device |
02-07-2012, 04:09 PM | #1130 |
02-07-2012, 04:34 PM | #1131 |
dang FF those lines are clean! i deal with salt spray here. i live within a mile of the ocean. i grind something 1 hr later it's flash rusting... the next day it's already got some pitting going on. that's why i sandblast and straight into the oven.
63 4 door Chevy II - NOVACATION (Updated 08/23/09) 65 Morris minor Traveler 77 Chevy Longbed. 93 Corolla JDM 20V Swap Daily Driver (Updated 07/16/09) Powder coating Hawaii Domestic Violence Awareness Show 5/3/09 Hawaii Rod and Custom Show 4/18 |
02-17-2012, 02:32 PM | #1132 |
Awesome work ff!! You just made my previous 2 days at work much more enjoyable. Can't wait to the finished product!
02-28-2012, 12:14 AM | #1133 |
Update Been workin on some of the loose ends. Getting very close to paint! Just a couple more fab items left. Got the fuel tank all sealed up- Weapons of choice: Before: Sudsy (Marine Clean) : Cleaned Inside: and out: Metal Ready in/out (drying) : POR-15 Tank Sealer Inside: Regular POR-15 Outside: Before: After: |
02-28-2012, 12:26 AM | #1134 |
Also made up a plenum/duct for the heater. This universal heater is becoming very specific...
The problem is that I can't mount the fan/motor assemble with the heater core under the dash. There's just no good place to package it together. So I split them up. You may have seen the fan mounted on the PS of the eng. comp in earlier pics. In doing so I created another challenge; directing the air into the heater core. There is a space between the two that must be gapped with a plenum. Here's the solution: Moved the fan opening over about 1.25" Flange on inside of firewall: Location from other side: Captive nuts: View of gap between firewall and heater core: Bridging the gap. I used posts to solidify the location/relationship between the core box and the flange: Then filled in the blanks with sheet metal and painted: |
02-28-2012, 12:43 AM | #1135 |
VA72C10
Nice!!!
Looking for a 67-72 swb or blazer project in or around VA. |
02-28-2012, 01:50 AM | #1136 |
Still Learning
Love the work on the tank and plenum FF. they look like they came original like that.
02-28-2012, 05:27 AM | #1137 |
FF how does one get the tank liner in? just pour and swish it around? looks good i'm wanting to do the same.
02-28-2012, 11:11 AM | #1138 |
67cheby
great work !
02-28-2012, 03:06 PM | #1139 | ||
Thanks!
Thank you! More to come this week! |
02-28-2012, 04:50 PM | #1140 |
This is still a universal heater for anyone with a 66 Sunbeam Minx with a Honda S2000 drivetrain and custom firewall.
Travis 2005 K2500 Duramax (hauls the junk home) 1967 Chev C10 (hauls a$$) 1970 Suburban (Yukon XL 4 door) 1968 GMC 3/4 ton (sheetmetal only, chassis gone) 2005 Malibu (wife's car, still a Chevy) Project Family Hauler New Home for Chevys (Moved in and working) |
02-28-2012, 09:46 PM | #1141 |
Just found this thread and read it from the star to the end. Incredible man, just wow.....
Keep up the good work. |
03-01-2012, 12:32 PM | #1142 | |
Yeah buddy! Was back at it last night. More to come today |
03-01-2012, 01:26 PM | #1143 |
I can't wait! I've loved following this build!
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
03-02-2012, 12:46 AM | #1144 |
Here you go. Nothing major, but little by little...
Fuel filler spout received the same treatment as the rest of the tank (sealer inside, regular POR out). Here's the tank with the pump installed and the spout with new rubber and OG clamps: ...removed all the brake/fuel lines, clutch and brake MC's, and pedals. Another loose end to tie up was the throttle pedal. I have not been able to install it since the firewall/tunnel was closed in. The design of the pedal pivot required it to be inserted from the right side. That was no longer possible as is: So I cut the pivot rod on the inside of the right pivot point (the right side will take ~90% of the stress), drilled, tapped, and welded a bolt to the removed side of the pivot: Result: Next, this little guy was the final remaining hold-out for closing in the firewall completely: ...that's as far as I got today (only had about 5hrs). Last edited by Frizzle Fry; 03-02-2012 at 01:36 AM. |
03-02-2012, 11:53 AM | #1145 |
Everything looks great Mike! Almost there......
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-09-2012, 08:19 PM | #1146 |
Heck Yeah Rob!
The local paint shop (Quality Paint Products) is having a hard time cross-referencing this blue into a "mix code." Here's what I have so far: VITON HALF-HOUR ENAMEL COLOUR CODE: 95 DESCRIPTION: Kingfisher Blue Crown BERGER REFERENCE: 404.2164 PART NUMBER 1 LITRE: 75242865 Looks like we're just going to do a color match. |
03-10-2012, 02:24 AM | #1147 |
You could always take a small piece with original paint on it and have them scan it with there spectrometer gun to get the paint formula.
03-10-2012, 11:45 AM | #1148 | |
But it's not an exact science; usually not a one step deal. You get close, spray it, go back and tweak the formula, continuing this way until its right. That's why it's worth the effort to find the factory data if possible. |
03-10-2012, 12:10 PM | #1149 |
Yes true. I've always had good luck with Rainbow paint. Just got done stripping a really bad primer job off a 58 VW 23 window micro bus with oven cleaner then buffing it out and fixing some bad body work and spotting it in.
03-10-2012, 03:14 PM | #1150 |
Still Learning
Great work on the throttle setup. Looking forward to the custom paint matching.
