Old 04-16-2002, 12:54 PM   #1
hjalbert
cracker
hjalbert's Avatar
Post quick question about tranny fluid
ok, my gmc has a 4 speed with granny low, guys at auto zone say it takes 80 wt gear oil, but they say 1 1/2 quarts, is this correct? another one, i cant find the plug on my rear diff, how do you check/add fluid? one more, any one know the cappacity for the transfer case? i usualy just put fluid in till it ocmes out the hole (do the same with the tranny, but i guess im wrong)
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Harry John Albert III
located in Phoenix, AZ
1972 GMC JIMMY,
1969 lwb Chevy Frame,
1999 bmw k1200 ltc
1992 Kawasaki concours
1991 bmw k75
1973 cortez motorhome
hjalbert is offline   Reply With Quote
Old 04-16-2002, 01:39 PM   #2
Blazer1970
Blazer1970's Avatar
Post
Rear end, tranny and t-case all use gear oil, and all fill until it runs out the fill hole. Not sure of capacities. With the 465, it is handier to pull the fill plug, then pull the shifter handle and pour the oil in through the shifter hole until it runs out the fill hole.
Blazer1970 is offline   Reply With Quote
Old 04-16-2002, 02:09 PM   #3
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Post
Your plug on the diff should be either on the pan on back or passenger side close to the pinion. If you want to drain it, you have to pull the pan and reinstall with a new gasket. You fill it till it runs out, just like the others.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
