Old 08-25-2006, 12:18 AM   #1
makovai
makovai's Avatar
Soon i can play with the big boys
Well...... I took the first step to the 3/4 ton running gear. I'm planning on putting the new 40" good years on my rig, but i figured i better toughin up the drivetrain first. I now own a 14 bolt corporate and another dana 44 but with a 8 lug.
Or as my wife explained to her friend as I was rolling them into the garage "4 tires and a couple of sticks"
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 08-25-2006, 12:38 AM   #2
MNorby
MNorby's Avatar
Re: Soon i can play with the big boys
What gears are they? Looks like there isn't a pinion shaft in the 14FF. I plan on the same, Already have everything except 8 lug outers for the 44. Am planning on running either 35s or 36s I have laying around. I hope the 44 holds up. Post pics of the swap! Can't wait to see.
MNorby is offline   Reply With Quote
Old 08-25-2006, 12:55 AM   #3
IGOR
IGOR's Avatar
I can't believe you got those unloaded by yourself. And where's the props, dude?
-Ben
1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer
1972 K10 - Rust Bucket, TBD
1976 C10 SWB, 350 / T350
My blazer build thread:
https://ck5.com/forums/builds/72-k5-...17-update.410/
IGOR is offline   Reply With Quote
Old 08-25-2006, 09:03 AM   #4
makovai
makovai's Avatar
Lets give props where they are due. Igor went with me as a consultant. He examined, touched, fondled, and played with the rear end, he said it was a go and i bought it . Actually he helped me alot and I appriciate it.
My 1/2 ton setup is running 4:56 gears and I'm doing 3200 RPM's at 60 mph, this new setup has 4:10 gears and i think it will improve my gas mileage from the 6 1/2 MPG i get now clear up to a hefty 7MPG.
The pinion is there it just isn't attached. The only thing i dont like about it is the wheels are 16.5, so I'll prolly have to buy new wheels but i can can use these until i get thing rolling.
I'll prolly take all winter making these look pretty, moving spring mounts, making new shock brackets, etc.... but some day i can be kewl and say "I have the 3/4 ton running gear.
www.fast77.com
1996 Z71 w/ 35's
Old 08-25-2006, 10:13 AM   #5
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Welcome to the 3/4 ton Blazer club. We are a rare breed. It would be a mistake not to run 4.56 gears though with 40 inch tires. I would definatly not run 4.10 unless you were 36 inch or smaller. Your milage may even suffer from having to work harder to get it up to speed.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 08-25-2006, 10:24 AM   #6
makovai
makovai's Avatar
It figures. I have the 4:56 gears in my 12 bolt, but of corse i dont have a ring and pinion in my D44 so i would need to buy both front and rear.
Since i already have the 4:10 gears I'll prolly set it up and see how it works, but you is prolly right, I'll be switching soon after.
www.fast77.com
1996 Z71 w/ 35's
Old 08-25-2006, 10:47 AM   #7
IGOR
IGOR's Avatar
Look on Ebay - you can find used gears all the time - you shouldn't have a hard time finding a set of gears
-Ben
Old 08-25-2006, 11:48 AM   #8
MNorby
MNorby's Avatar
I have 4.56s in my D60/14FF combo on my truggy with 40" TSLs and it works good and sometimes I wish for 5.13s... but that when the doubler kicks in
Old 08-25-2006, 11:56 AM   #9
makovai
makovai's Avatar
please post pics of this rig
www.fast77.com
1996 Z71 w/ 35's
Old 08-25-2006, 12:07 PM   #10
MNorby
MNorby's Avatar
Once upon a time:
Currently:
Old 08-25-2006, 12:35 PM   #11
IGOR
IGOR's Avatar
nice!
-Ben
Old 08-25-2006, 01:08 PM   #12
krue
Designated A-hole!
krue's Avatar
The 3/4 ton gear swap is on my list.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-25-2006, 02:26 PM   #13
onetonk5
Cereal Killer
onetonk5's Avatar
thats a great upgrade.....im planning on using a 9.5 ring gear sf 14 bolt and keep my truck 6 lug. I just dont feel the need to lug around the extra weight of a ff 14 bolt but if your ever planning on doing much offroad it gives you the confidence that your most likely not going to have any rear end problems.unless your running mega power and Big tires. A disk brake swap is simple and pretty cheap.
onetonk5 is offline   Reply With Quote
Old 08-25-2006, 02:53 PM   #14
2wdBlazer
The Blazer King
2wdBlazer's Avatar
If you don't drive interstate alot a 4.88 would be perfect. 4.56 if you do hit the interstate.
Old 08-25-2006, 04:41 PM   #15
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 08-25-2006, 07:05 PM   #16
vtblazer
vtblazer's Avatar
You'll love the new beef for sure.
What are you planning on for suspension? Going longer springs?
vtblazer is offline   Reply With Quote
Old 08-25-2006, 07:23 PM   #17
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I had 4:10's in my '69 with 35's and it was perfect. I was getting in the 6-8 range with that rig. I think your going to see you MPG drop with the 4:10's and the bigger tires. My '72 with the stock tires, engine and 3:07 gears is getting 12-13mpg.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-25-2006, 08:02 PM   #18
IGOR
IGOR's Avatar
Well it's official Jim - the Board has spoken - you must go 4.88s or 5.13s! My vote is 4.88 - it's your toy anyway
You can get 5.38s for a 14 bolt now too - but the supplier (Randy's Ring & Pinion) is getting roasted on Pirate4x4.com right now for machining grooves in the pinion bearing support shaft in the 5.38 gear set - the "Pirate" jury is still out on whether this is okay or not.
-Ben
Old 08-26-2006, 09:20 AM   #19
makovai
makovai's Avatar
the suspension will remain the same I just put new springs (skyjacker 8" softrides) so I'm gonna make the new running gear fit that. The front should bolt right up, especially since im just gonna change the ends and keep my original pumpkin. The rear will have to be moddified for the narrower spring pads.
www.fast77.com
1996 Z71 w/ 35's
Old 08-31-2006, 09:23 AM   #20
makovai
makovai's Avatar
I took the first step to get me motivated. I sold the wheels and tires. I think it shows alot of class. Not just anybody would let there blazer be seen like this.
www.fast77.com
1996 Z71 w/ 35's
Old 08-31-2006, 09:53 AM   #21
bpmcgee
bpmcgee's Avatar
ROFL.
You're going to need a bigger jack!
Brian
bpmcgee is offline   Reply With Quote
Old 08-31-2006, 10:00 AM   #22
IGOR
IGOR's Avatar
What's up pimpin?
-Ben
Old 08-31-2006, 03:37 PM   #23
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Reminds me of Bouncytruck!! :nut:
Old 08-31-2006, 04:25 PM   #24
IGOR
IGOR's Avatar
Man that was low!
-Ben
Old 08-31-2006, 04:30 PM   #25
Southedisto
River life......
Southedisto's Avatar
So whats with the picture of the 4 small tires? Congrats on the upgrade, are you converting to disc in the rear?
Southedisto is offline   Reply With Quote
