Old 08-27-2002, 08:50 PM   #1
kenele
kenele's Avatar
valve on the heater core hose
I have a problem with hot air constantly coming out of the vents in my truck . I heard mention of a valve that can be placed on the heater core hose that shuts off the flow of water to the heater core when not in use. Is this a stock item that someone has removed from my truck or is it an aftermerket idea? Does anyone know how they work , are they manually operated or vacuum operated?
'71 GMC Suburban C1500
kenele is offline   Reply With Quote
Old 08-27-2002, 08:58 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Think of it like installing a water spicket in your hose, it works the same way.
20 bucks at napa.
Old 08-27-2002, 09:00 PM   #3
Alex Hayley
Which hose is that valve installed on?
Alex Hayley is offline   Reply With Quote
Old 08-27-2002, 09:04 PM   #4
kenele
kenele's Avatar
Longhornmail.....do you know what the name of that valve is called.?
is there a switch in the cab?
Old 08-27-2002, 09:16 PM   #5
Mountain Man
I have installed a shut off valve on my truck for the same reason, hot air in the cab.
I have a non/ac cab, so I installed the valve on the lower heater hose, the one from the intake manifold. This is the one that flows into the heater core. The upper one is the return hose to the water pump.
Just splice into the heater hose, and install a ball type shut off valve. The one I used was in the plumbing section at home depot. It is even gold and chrome colored, and looks good. It is actually brass inside. Approx $12.
Works great. I have an engine pic on file that I can attach, but you can barely see the valve:
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 08-27-2002, 09:20 PM   #6
Jesse 67 c-10
Jesse 67 c-10's Avatar
go to a hardware store and get yourself a 1/2" ball valve, 2 barbed fittings to fit your hose size that screw into the valve, and 2 hose clamps. cut your heater hose, shouldn't matter which one, plumb it in, start and warm up motor with valve open and check for leaks, shut it off when you dont want heat. simple, and easily done for under $10.
Jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 08-27-2002, 09:23 PM   #7
Jesse 67 c-10
hey, we posted the same answer, almost, at the same time!
Old 08-27-2002, 09:34 PM   #8
kenele
kenele's Avatar
Thx for the help
i am gonna install the ball valve...damn tired of sweating on 75 degree days.
Old 08-27-2002, 09:53 PM   #9
oldiron
Designated Grumpy Old Man
oldiron's Avatar
How is that new engine working out? If you are around this weekend maybe we could meet somewhere.
oldiron is offline   Reply With Quote
Old 08-27-2002, 11:14 PM   #10
kenele
kenele's Avatar
this weekend
only thing I got going on this weekend is gonna try and contact Breeh and go pick up that free bench seat from him.
Old 08-27-2002, 11:17 PM   #11
kenele
kenele's Avatar
p.s.
Oh yeah and the engine is doing good after i fixed the lower radiator hose that was only half on and leaking.....but I think the tranny might need a rebuilding here pretty soon...hehe.wait'll i tell the accountant .........she's gonna love that news
Old 08-27-2002, 11:17 PM   #12
oldiron
oldiron's Avatar
Sounds like fun. How is Monday looking?
Old 08-27-2002, 11:21 PM   #13
kenele
kenele's Avatar
Monday sounds good
let me know where and when and I am there
Old 08-27-2002, 11:28 PM   #14
oldiron
oldiron's Avatar
How about where you took your picture. 10 am. Legion Park.
Old 08-27-2002, 11:36 PM   #15
kenele
kenele's Avatar
10 A.M. it is
cool...can't wait to check out that headliner.. gonna try and build one. I'll look for you on the swings....LOL
Old 08-27-2002, 11:36 PM   #16
oldiron
oldiron's Avatar
Check your Private Message for Phone #'s
Old 08-27-2002, 11:54 PM   #17
kenele
kenele's Avatar
if your interested
Last friday evening we went down to Hwy 99 and about 170 th street in Lynnwood to the informal car show that they have weekly. There were a couple of NICE 67-72 chev's and a lot of other cars. we might go again this week.
Old 08-28-2002, 12:23 PM   #18
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
The valve from NAPA is brass, but it has a weird screw thing to shut off/open it up. It is possible for it to leak. You have to screw it all the way in, or all the way out to help (I said HELP) prevent it from leaking. Ball Valves are positive closers...the ball seats against the seat and blocks the flow. Even tho I have the NAPA valve and it isn't leaking at this time, AND it was a lot cheaper than the vacuum-operated valve that went bad, I'm gonna consider a ball valve when this one goes bad.
Member Nr. 2770
Old 08-28-2002, 10:48 PM   #19
kenele
kenele's Avatar
screw top valve from napa
I put the little valve from Napa and it worked like a charm although a little over priced @ $20 I know its gonna make a world of difference.
Old 08-30-2002, 05:57 AM   #20
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Most Japanese cars have a nice cable operated valve for the jeater that is mounted on the firewall. They are real nice for your purpose.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
