Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-28-2008, 12:22 AM   #1
fun in dirt
fun in dirt's Avatar
Add a lil bling with some lights
I've got a new sound system ordered for my Blazer & trying to do a little wiring pre-planning during the wait on it to arrive.
I'm gonna put the amp under the console (on a custom made stand so it will get plenty of air) and want to put a neon light there too. Can I wire this light to the power input on the amp or is that a big no-no?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 02-28-2008, 12:35 AM   #2
Classic69
Love That '69
Classic69's Avatar
Re: Add a lil bling with some lights
I wouldn't suggest it, depending on the output of your amplifier. Your gonna be using probably 4 gauge wiring for the power line on the amp. While the wiring for the neon/LED tube will only be like 14 gauge.
I would suggest a separate switched connection for the neon lighting. That way you can turn it on when you want to, instead of it always turning on when you turn your stereo system on.
I AM CANADIAN!!!!!
1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights
2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates
Classic69 is offline   Reply With Quote
Old 02-28-2008, 12:56 AM   #3
AceX
>130dB Moderator
AceX's Avatar
I'm with Classic69 on this one. Wire it in a a switch like with the dome light or something like that. There's alot of times where you won't want the light to be on...
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
