Frame bent, what to do?
Ok so I came across this 71 c10 frame and a cab, mainly I needed the cab due to the cancer mine has. Since the frame is a five lug disc short bed I grabbed it too. Now you can see in the pics from the spring mounts back it is twisted, the rest of the frame is square and true. Obviously the rust around the spring mount caused it to be weak and due to a rear end accident I presume this happened. Now comes the question of is it fixable or should I say price wise is it fixable, I’m a poor guy here. I really would like to start building my second c10, this one a short bed compared to my current long bed step that I drive daily.
I would take it to a local body shop to see if it is worth doing, but as you can see I am still in need of a rear axle and that makes it fun to move. So I thought you guys could put some info in before I get too excited about having a shorty to work with. Any info appreciated so let it roll, I’m all ears.
Mark 1967 C/10 stepside lwb daily driver 1968 C/10 fleetside lwb parts truck 1971 Cheyenne Super swb project |
Re: Frame bent, what to do?
More
I would get another frame. We just sold one for $100.00 .
Frame shops charge $98.00 per hr |
from looking at the picts I would see if I could get the frame redone what I mean is to cut it and make my own back half just a thought I think it could be done but then again is just an idea. Try the link below it kind of gives you an idea of what I am talking about...
http://www.gmfullsize.com/forum/show....php?p=2617378
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
![]() Join Date: Sep 2005
thrash it its junk you can get a used on not bent for like 100 buxs around here
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Redefining LowBudget
being from the poor part of town too...I would
grind off all the rivits and see whats left then thinking forward about what I wanted my next truck to be and do make decition from there....you could clip it and make a new frame and pro street it, you could pull it back down and box it (probably what I would do) or buy a notch kit and build it in...... anyway what you want your next truck to be should be your first choice but by the looks of things...pro street beater looks like the easy thing to do and you could build it around what ever axle and wheel combo you can find cheap at the swap meet as long as the tires where big and wide......then you can cup your own lower control arms throw some bags under it and have some fun just my $.02 |
its all about the +6 inches
ummm, i'd consider trashing it just due to the rust building up like that. And this coming from a midwestern guy... not a spoiled southwestern guy.
I got a free 67 frame that's less rusty than that, and straight as an arrow... I'm going to ditch it for another.
I consider my time working on something like this to be free, but at the same time, you have to draw the line, and let some things go. Like this frame for example. Last edited by Jim_PA; 09-01-2009 at 10:59 PM. |
![]() Join Date: Jul 2004
Frame is gone, get a better one, mainly the rust problem, but the bend trashes it for sure. That is the foundation for your build, and you want it right, hate to put $$$ into a truck on a bad frame.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
![]() Join Date: Jan 2008
If the frame rust stops there, you could clip it with another the same way guy's do it when they make a long bed frame a short. My .02
Sorry for not adding the pics of the rest of the frame. The rest looks very good. Worst case at least I can use the five lug disc set up off the front, although I am thinking about some of the others guy suggestions.
Thanks for the info and ideas, as always.
I think a step notch would cure that. Measure twice, cut once.
#13 |
Moderator
![]() Join Date: May 2007
If you keep it, plan on taking it to a frame shop and paying $300-$500 to get it aligned.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#14 | |
Just Not Low Enough!
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd ![]() Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
#15 |
You are not allowed to sell you parts here. Because you are not a subscribed member.
Last edited by fine69; 09-07-2009 at 01:05 PM. Reason: offering parts. NOT allowed. |
