01-13-2010, 12:32 AM | #1 |
Keep On Keepin' On
Plumbing rear gas tank...
I bought this exact tank from boyd welding. Their website says the top hole in the middle is a vent and a hole in the opposite lower corner is the fuel hole. Can someone give me an idea how I need to plumb this thing!
07 Avalanche Z71 92 Mustang 5.0 GT (Triple White w/ 53,000 miles) 72 SWB Chevy w/ PS, AC, 350/350 Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)... http://67-72chevytrucks.com/vboard/s...d.php?t=157669 |
01-13-2010, 01:26 AM | #2 |
Re: Plumbing rear gas tank...
I would look for plumbing instructions for a standard fuel cell. it should be the same
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
01-13-2010, 12:01 PM | #3 |
My best guess...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-13-2010, 12:07 PM | #4 |
Under Construction
I agree with Rob, there should be another hole on the lower bottom etc, for a nipple to run a hose or hardline too for the fuel line. I would not hesitate to contact Dave with boyd welding...
I attached a pic of ours, different manufacturer but same concept.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 01-13-2010 at 12:10 PM. |
01-13-2010, 12:08 PM | #5 |
vw guy & now c-10 guy
I think the Boyd's guy is a member on here, right? send him a PM or something. Im sure he'd be the best one to ask.
01-13-2010, 12:49 PM | #6 |
The hole on the bottom will go to your fuel pump, filter and carb, the small hole on the top will go to a vent tank or charcoal canister or vent filter, the large hole on the top is for your sending unit and will be wired to your gauge.
The one with the cap on it is to fill the tank, but I'm guessing you knew that one. Give Dave a call, he'll be more than happy to help you out. Last edited by Dynomutt; 01-13-2010 at 12:54 PM. |
01-13-2010, 07:07 PM | #7 |
Keep On Keepin' On
Thanks for input...My return gas line..Do I need it? If not, what do I do about the extra line at the fuel pump?? Help!!
01-13-2010, 09:09 PM | #8 |
Active Member
Are you running FI or carb?
Electric pump or mech?
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
01-14-2010, 01:48 AM | #9 |
Keep On Keepin' On
Carb and mechanical
01-14-2010, 11:39 PM | #10 |
You could go with an in-line electric pump and regulator and not use a return.
