Old 12-22-2010, 05:08 PM   #1
mccormick
mccormick's Avatar
Best 4 inch lift kit for 71 chevy
ive got a 71 that i want to put a 4 inch lift on and just curious what everybody is running and what the best kit is
wont be doing much off roading with the truck but i still want to put a quality lift on it, i dont want a block lift
hopefully there is some insight on the subject!!
thanks in advance
Brett
mccormick is offline   Reply With Quote
Old 12-22-2010, 05:16 PM   #2
69CSTDawg
69CSTDawg's Avatar
Re: Best 4 inch lift kit for 71 chevy
cant you use a basic lift with the blocks and run a shackle reverse and just throw out the blocks?
69CSTDawg is offline   Reply With Quote
Old 12-23-2010, 12:05 AM   #3
CrewCab59
CrewCab59's Avatar
I have always liked skyjacker and springs all the way around.
CrewCab59 is offline   Reply With Quote
Old 12-23-2010, 07:51 AM   #4
I really like the Tuff Country EZ-Ride lifts. They are reasonably priced and give a great ride. They are located in Utah,so shipping to you may be better than other places.
www.suspensionconnection.com
Old 12-23-2010, 10:41 PM   #5
chisler
chisler's Avatar
X2 This is the way to go !!!!!
chisler is offline   Reply With Quote
Old 12-23-2010, 11:54 PM   #6
mccormick
mccormick's Avatar
The tuff country lift with all springs looks really reasonably priced and has the brake line extensions and steering correction...
the skyjacker seems to be more expensive, and a bit tougher to figure out what i need.. they also have the option for 56" springs instead of 52" .. any ideas behind that?
I'm a bit of a rookie when it comes to lifting these old things sorry if these questions seem dumb
Old 12-24-2010, 12:07 AM   #7
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
here are some shackle flips for the rear. keep the stock springs and gain 4" of block free lift (5" if you recenter the rear axle with a zero rate)
http://diy4x.com/cart/index.php?rout...product_id=112
http://offroaddesign.com/catalog/shacklekit.htm
I'm going with the off road design for my 68 K20 when I pull the blocks out. My buddy just did it to the rear of his 85 k30 Single and it functions good and keeps his load capacity and ride quality where it should be.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 12-24-2010, 08:54 AM   #8
silver7
silver7's Avatar
I believe springs all the way around is the way to go. Rear springs lifted with blocks look cheap and hillbilly. To each his own, just my humble opinion. You could always buy an add-a-leaf if you want to save $.
I went with Superlift but can't say why since they all are near the same price. Rough Country is probably the cheapest.
Shawn
1971 C10 4x4
silver7 is offline   Reply With Quote
Old 12-24-2010, 10:27 AM   #9
CrewCab59
CrewCab59's Avatar
$$ spent is well worth it,they ride much better than most and are almost ride like custom made springs. You'll want to spend some time looking at how the springs are made ( taper vs end cut,slide pads,kit or system .
The 56" rear springs are used in the mid 80's and up burbs,and trucks.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
Old 12-24-2010, 12:54 PM   #10
swamp rat
swamp rat's Avatar
On sale now.
http://www.suspensionconnection.com/...on/166114.html
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-24-2010, 03:05 PM   #11
mccormick
mccormick's Avatar
I'm not worried about money spent i want to do it right.. i don't think i want to do the shackle flip.. i will probably go with one of the 4" kits with springs all around.
Not sure which one yet, i will research them a little more but thanks for the base info help guys.
Old 12-24-2010, 03:16 PM   #12
mccormick
mccormick's Avatar
http://www.4-wheel-drive-lift-kits.c...r-springs.html
That is a link to the skyjacker lift...
curious what the optional steering correction and steering stabalizers are?
the tuff country doesnt have them.. would they make a big difference?
I have a fabtech lift on my Fj cruiser.. i really like it, but can't find anything on Fabtech or even Pro Comp for lifts on these old trucks. im assuming they dont make any?
Old 12-24-2010, 07:19 PM   #13
CrewCab59
CrewCab59's Avatar
Steering you have a drop pitman arm, raised steering arm or a S drag link.
Skyjacker,Superlift,Rough country is about the only ones left.
1971 Chevy C/10
Old 12-25-2010, 02:28 PM   #14
Tuff Country kits come with a lift steering arm for correction. They offer a steering stabilizer,too. Those are just heavy duty shocks layed out horizontally with mounting brackets. If not,you can get them anywhere that sells 4wd stuff.
Old 12-25-2010, 05:41 PM   #15
silver7
silver7's Avatar
I've bought most of my truck stuff from www.summitracing.com. I remember they sell Superlift and Skyjacker kits. Not sure how the price compares but their customer service is hands down the best I've delt with.
Shawn
1971 C10 4x4
Old 12-28-2010, 05:49 PM   #16
Oilbrnr
Oilbrnr's Avatar
x2
I really like the ride with the EZ's in my K5. Going to put some in the old K20 next.
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
