Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-31-2012, 12:59 AM   #1
67chevysupercharged
67chevysupercharged's Avatar
9in for sale
I was on craigslist and found an ad for a 9in from a 79 Bronco for sale and was curious if anyone has used one in one of their trucks. It says it is a complete rearend with brakes, detroit locker, 65 inch WMS to WMS from 79 Bronco, 3:50-1 ratio, 1 axle needs new seal. asking 575.00. I was hoping someone could tell me if this sounded like a good price, and what all I would need to look for, and whether or not this will work in my truck. The truck is a 67 swb stepside with a turbo 400, and a big block.
Thanks, Zak
71 Longhorn 402, PS, PDB, AC, Tach, Posi
67 SWB 6.0 LSX swap, 4/6 ECE Drop (Work in Progress)
2002 Victory Red ECSB Silverado 5.3 (DD)
67chevysupercharged is offline   Reply With Quote
Old 01-31-2012, 08:27 AM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 9in for sale
Yes , i have used 2 of these . I always narrow mine as i dont have a fullsize . These should be heavy duty housing with big bearings , 31 spline , full size brakes and with 3.50 gear both i pulled apart had rebuildable limited slips . With the limited slip even if you go spool you can sell the posi and recoop some money .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 02-01-2012, 12:53 AM   #3
Captainfab
60-66 Nut
Re: 9in for sale
The 12 bolt that is in your '67 is 62" wide, so that 9" is a bit wider.
Old 02-01-2012, 10:14 AM   #4
nomrlz
nomrlz's Avatar
Re: 9in for sale
i'm buyin a late 70's chevy that has a 9" in it as well as th400 and a 69 396. i'm buyin it for the engine to put in the kids 68 camaro. then gonna scrap truck saving the trans and rear to sell. i was hopin for $200 from the rear. $575 seems high to me
nomrlz is offline   Reply With Quote
Old 02-02-2012, 12:19 AM   #5
67chevysupercharged
Re: 9in for sale
Thanks for the replies. Right now I am on the fence as to whether or not I should go ahead and rebuild the 12 bolt I have or upgrade to a 9 inch. I'm hoping to make more power in the future, so the 9 inch seems like the good choice. But money's tight right now, so I don't which to choose.
Old 02-02-2012, 12:39 AM   #6
vin63
It's Better With Nitro
vin63's Avatar
Re: 9in for sale
If you're comparing stock units, the 12 bolt will probably hold up better, and depending on how much power you plan to make it may be cheaper to build out. The 9-inch rears that you see in a lot of drag cars do not have much in common with their stock rearend brethren.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-03-2012, 03:00 AM   #7
67chevysupercharged
Re: 9in for sale
Well right now, the 396 is just going to be a simple 10.5:1, pro comp aluminum heads, and decent hydraulic roller. Hopefully a blower, or 502 swap will be in order, but I just want a rear end that can handle 450-500hp from the 396 reliably until a moser or currie unit can be ordered up. If I rebuild the 12 bolt, it's going to get new ring & pinion, posi, installation kit, and seals, which I think should handle it alright.
Old 02-10-2012, 09:10 PM   #8
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Re: 9in for sale
I called about a bolt in 9 inch for 750 hp street strip set up complete. 3800 bucks.
GMR-PERFORMANCE is offline   Reply With Quote
Old 02-12-2012, 05:09 PM   #9
Blue Rat
Re: 9in for sale
I know, I have made that call too. The bad is I do not think my 12 bolt will hold up too what I am going to throw at it. If it does not then I just threw $1400 out the window. So, think I am going to save the money an do everything right about July or August. By then I should be getting ready to put it on the road.
Blue Rat is offline   Reply With Quote
Old 02-12-2012, 08:47 PM   #10
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: 9in for sale
The 12 bolt is a 8.875 ring gear and the 9 inch is well 9" , the 9 also has 3 pinion bearings and a removable case . 9 inch is my choice .
Also the 9 ich parts are plentyful . I went to a swap meet last weekend and drag as well as circle track guys use this stuff . Parts were everywhere and reasonable . You can get an idea about were your going/what you want and start shopping now . Center section parts are generic pretty much , so you can buy the case , pinion support and spool / differential based on the plan you have . Say you want to run 31 , 33 or 35 spline you can start shopping swap meets and auction sites for a locker or spool . U-joint size will determaine which yoke you need . gears are avalible in what ever so if you come across a good deal , buy it . Start making a pile .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 02-12-2012, 11:58 PM   #11
GMR-PERFORMANCE
Re: 9in for sale
I have a 35 spline spec'd out it will be drum to drum and that is my plan. I have gone the 12 bolt route in the past today I have a extremely low opinion of "how" strong they are not.
That being said I over build most things I do any ways but thats my job. I would rather take longer and pay a bit more up front to do the job once vs having to throw money away and then still have to take the next step.
I ran a 35 spline in my old S15 truck and that would leave on the convertor at 6500 RPM with a 150 HIT off the line. Running on 30X15 firestones at the time. Let that SB off the leash and it was a wheels up launch on or off the bottle.
I broke just about everything I could think off, but that rear diff could take any thing I could throw at it.
Old 02-13-2012, 06:25 PM   #12
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Re: 9in for sale
$575 for what you said is included is CHEAP.
My advise is don't throw good money after bad.
Good luck with your choice.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
