02-22-2014, 02:39 AM | #1 |
You know your motor is apart too often when...
I am sure there are a lot of us that can add to this. I will start.
You know your motor is apart too often when: It takes you 1 hour and 30 minutes to get it out by yourself You can collect the mix of tools you needs before you even start. (In my case both metric and standard) It takes you less than 1 hour to assemble from Shortblock to complete turn key ready minus dropping it in and wiring it. But that's only another hour.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
02-22-2014, 04:06 AM | #2 |
Re: You know your motor is apart too often when...
You can pull the tranny from the truck laying on your back in less than 30 mins and then pull the motor with your eyes closed...almost.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
02-22-2014, 09:58 AM | #3 |
Registered Truck Offender
When you have to replace the bearings in the wheels of the engine hoist!!!
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
02-22-2014, 01:03 PM | #4 |
You know exactly what does and doesn't have to come off in order to get the engine on the stand the fastest. You just remove the components to the get the belts off instead of bothering with the belt adjustments.
With air tools I got to the point I could yank the engine in 35 minutes from my 84. Everything was about as simple as it could get for hookup. One -8 fuel line. Pull the carb and attach the lift plate. Then drop the alternator and ps pump. Headers were the biggest pain. Never did find a quick way to get them out especially the bolts that had to be wrenched out.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
02-22-2014, 11:52 PM | #5 |
Always a work in progress
When you have more pics of it out of the truck than in it!!
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
02-23-2014, 12:01 AM | #6 |
At the body shop.
When you beat the firewall back to remove the bell housing bolts easier.
" That didnt make it any newer " " Dont antique the equipment " |
04-18-2014, 05:27 PM | #7 |
When its a weekend thing.
04-21-2014, 11:14 AM | #8 |
When you have to ask this question..
62 long box with a little SBC http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
04-21-2014, 02:40 PM | #9 |
Boosted Member
You put quick disconnects on your tranny cooler lines
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
05-31-2014, 05:12 PM | #10 |
your wife isn't getting mad at you over how long this particular job is taking....
05-31-2014, 09:17 PM | #11 |
When you put all your bolts in the same bucket because you know where they go!
06-05-2014, 08:30 AM | #12 |
Certified BFH Operator
When you make brackets with D-rings on them, and bolt them to your heads so you don't have to pull your intake or carb and can just hook a chain to them!
- 1969 swb C/10 fleetside -LSx swap and Resto in progress LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay... -1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle |
06-05-2014, 12:54 PM | #13 |
When you have to heliciol all the holes due to wear.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
06-05-2014, 10:29 PM | #14 |
when you say TO HELL WITH IT,, I'm done!
The truck is going back to just a street truck,, and getting the Nova all re-certed. At least that POS stays together a bit longer.
06-06-2014, 04:56 AM | #15 |
06-06-2014, 09:38 AM | #16 |
Yeah,, thanks for the concern guys . I'm just tired.
Haven't touched the truck since it broke the pushrod in March. I'm sure it's got a hurt lifter. Has to come apart to find out. Think I've just kinda lost interest in even fixing it. "EVENTUALLY" Going to put the heads on a nice little pump gas 383 I built for it originally, with a hydraulic roller, and headache free single carb,,,, and see what happens. I'm thinking its apt to find a new home.
06-06-2014, 12:31 PM | #17 |
meowMEOWmeowMEOW
You know your motor is apart too often when you look at a Fiat and think..."man, it would be nice to own a reliable car..."
06-06-2014, 09:42 PM | #18 |
When it is still apart... Yes, mine is still apart..
06-07-2014, 12:32 AM | #19 |
Hollister Road Co.
When you try to think of a way to put zippers and snap buttons on everything
07-14-2014, 04:52 PM | #20 |
Hahaha that made me laugh
Austin 1996 Chevrolet K1500 Silverado 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
08-16-2014, 11:17 PM | #21 |
08-17-2014, 12:44 AM | #22 |
i have been pulling old chevy engines for over 20 yrs that even if the engine is supposed to come out the bottom i still pull it out the top and can do it twice as fast as most people
