Old 07-31-2014, 01:35 PM   #1
Ackattack
Ackattack's Avatar
How many miles on your conversion
How many miles are on your conversions and what issues have came up?
I have a little over 20k on mine now and I had a couple of issues pop up.
- On one of its maiden voyages, my batteries died....turned out the voltage regulator had came unplugged.
- I rebuilt the transfer case shortly after I started driving it. The transfer case oil pump had a lot of silicone grindings stuck to the screen. I should have got a new pump, but I didn't and just cleaned off the screen and went on and rebuilt the TC. A few months later a few roller bearings and shift fork began to eat themselves. By this point it was my only ride, so I just bought a whole new TC.
- I lost 5th gear. When I rebuilt the transmission I bought an upgraded shaft to prevent the 5th gear nut from coming off. Well the 5th gear nut didn't come off, but some how the snap ring that holds 5th gear on came off. Luckily I was able to make it home in 4th gear with no other damage. A few dollars for a new snap ring and about $100 for new oil and I was back in business.
- Had to replace a u-joint....no biggie.
- The worst one, which required a tow, was when my front panhard bar (aka trackbar) cracked the frame and was flexing side to side. I was only doing about 20mph when this happened and it shook side to side violently.
So for driving it for a year and a half: not terribly bad. With a conversion like mine I kind of expected a few hick ups along the way.
Ackattack is offline   Reply With Quote
Old 08-01-2014, 11:11 AM   #2
dieseldude4bt
Re: How many miles on your conversion
80,000 on mine, replaced a couple of U joints and a transfer case.
Not bad for 14 years.
63 k20 with cummins 4bt, owned sence 1982
dieseldude4bt is offline   Reply With Quote
Old 08-27-2014, 07:49 PM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
The wife has over 5k on the Excursion and I haven't done anything to it since the ring and pinion. I need to fix the no power issue to the AC comp, but it's been going strong. My 95 F-350 I drove daily for 3yrs and put on over 120k on it. It's apart nor for a front end rebuild and a krylon over haul.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-27-2014, 11:09 PM   #4
6BT 56
6BT 56's Avatar
i just did my second oil change on mine . granted im doing them a little early at 5k as im trying to clean the eng up a bit as it was denied some love in its 1st life . i will step it up to 10k now . All i have really done is put in some new front leaf springs and tweak a bit of front end steering geometry . There is still plenty on the list tho. lol
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 09-13-2014, 11:00 PM   #5
COS399
COS399's Avatar
The 12 valve that is in my 88 has been in there about 14 years and I have probably put about 70K to 80K on it.
2000 - I had to remove an inline fuel pump that was restricting fuel flow to the lift pump. It was one of those small square electric fuel pumps that the mechanic had put in to prime the system. I also had the injection pump and two injectors rebuilt.
2003 - water pump went out
2005 - slave cylinder on the clutch went out
2007 - replace the fan clutch
2008 - clutch master cylinder and connecting rod pushed through the firewall due to improper/poor installation when converted in 2000
2009 - fuel restriction in right fuel tank due to the factory gasoline electric fuel pump still in the tank. I had to remove the pump and extend the draw straw.
2011 - replace leaking head gasket the head gasket
I am very glad I had this thing converted. I just wish I had done it sooner.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
