Yeah baby!
Trans Shield?
Can you fit a trans shield to a TH400 while it is in the truck? It's a 1968 low hump. I'd prefer a shield over a blanket due to heat on the street.
11.37 @116 |
![]() Join Date: Jan 2011
Re: Trans Shield?
Will depend on the shield and the height of the trans. Some fit closer than others. You may be able to drop the cross member and slide it up from the back. Do you know how much room you have between the trans and the floor?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Re: Trans Shield?
Not sure about a TH400, but I had to lower my TH350 on the back to do mine the time it was in the truck still, also low hump.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
meowMEOWmeowMEOW
Re: Trans Shield?
With my 4l80e, I think a blanket would fit since it can hug the irregular shape, but I don't think the shield would fit just based on eyeing it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Yeah baby!
Re: Trans Shield?
I've not measured it yet but I like the look of this one:
http://www.hughesperformance.com/pdfs/hp9800.pdf
11.37 @116 |
Re: Trans Shield?
I run a TCI, pretty much the same as that Hughes.
![]() Join Date: Mar 2008
Re: Trans Shield?
I don't have a stock tunnel but I have slid mine on from the rear.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
Yeah baby!
Re: Trans Shield?
There is about an inch and a quarter between the floor and the trans. How much space do I need?
11.37 @116 |
It's Better With Nitro
Re: Trans Shield?
I've never been able to install a trans shield without either dropping the trans down, or have a full access removable trans tunnel. I install trans blankets routinely for customers without removing the transmission. I just need to make sure I can access the top two trans/engine block bolts to secure the tabs.
