Old 09-23-2015, 10:39 PM   #1
olebluegmc
My 72 Gmc c25 project
I bought this project a few months ago and have gotten some minor progress, but am plugging away at it slowly but surely. My plan is to put an ls motor in it and drive it daily, in the nice season ! Its a 1972 GMC C25 originally a 350 with a 4 speed, but I've already pulled and sold that setup. This is my first oldschool project and I didnt know what I was getting into when I pulled the trigger on this. LOTS and LOTS of rust ! Cab was pretty much shot, between the 2x6 custom wood rockers, and majority of panels rusted out.
olebluegmc is offline   Reply With Quote
Old 09-23-2015, 10:46 PM   #2
olebluegmc
Re: My 72 Gmc c25 project
Decided to go the route of buying a "better" cab from Tennessee when on vacation. Actually got my cab from Dwayne from insane hot rodz, awesome guy that does top quality work. Since then I've dug into the cab and have been repairing the typical panels. I built a wooden dolly to roll my cab around on for $30 from a pallet 2 pieces of 4x4 plywood and 2 moving dolly from harbor freight .
Old 09-23-2015, 10:51 PM   #3
olebluegmc
Started with what I think will be the hardest panels to replace which are the cab mounts. Tons of spot welds to get at it and get them off. Got them welded up and undercoated the inside to prevent future rust. I taped off the areas that will come close to welding to prevent melting and allow me to spray weld thru primer. I need to touch up the mounts a little, but this is a learning process for me. I'm not a professional by any means, just someone that is determined to tackle new things.
Old 09-23-2015, 10:54 PM   #4
olebluegmc
Just test fitting the outer floor extension. Now that the rear mount is in I am going to start on putting the new rear floor patch in and then the cab corner.
Old 09-23-2015, 11:38 PM   #5
NTIMID8R
NTIMID8R's Avatar
Looks like you got your work cut out for ya... literally ...
Seriously, nice work so far.
Yesterday is history, tomorrow is a mystery, today is a gift, that's why it's called "the present".
1971 Sierra Grande LWB, 350/TH350, Factory Air Lots, of future mods planned!!
NTIMID8R is offline   Reply With Quote
Old 09-24-2015, 12:34 AM   #6
olebluegmc
Haha sure do ! And thanks ! I'm doing my best to get er' done right and not cut corners
Old 09-24-2015, 07:15 AM   #7
hugger6933
Are you lapping the inner floor piece and then gonna weld that lap joint style? I used a floor piece just like that on the last one I did, once the floor piece was in, i ran a die grinder don the seem then welded it up. Jim
hugger6933 is offline   Reply With Quote
Old 09-24-2015, 07:17 AM   #8
hugger6933
With it in and screwed down like yours showed if you go down the seem it leaves a real good seem to weld. Jim
Old 09-24-2015, 10:06 AM   #9
olebluegmc
I'm planning to butt weld the piece in. I know it would be a lot less of a pain to weld it like that but I don't want moisture caught between the pieces and also don't want it visable from underneath ( not that I'll have tons of people crawling under the truck).
Old 09-24-2015, 10:42 AM   #10
72kool
72kool's Avatar
looks like you have a good running start on it. i have the same truck but orange/white paint combo. will be watching your thread so il know how to do mine. nice work so far
72kool is offline   Reply With Quote
