11-09-2017, 11:52 PM | #1 |
drop Spindle
can anyone tell me if Classic performance product 71-72 C-10 front spindle with disc brake. will fit a 1969 c10 with factory disc brake not sure if 71-72 will fit a 1969 C-10
11-10-2017, 10:23 AM | #2 |
Re: drop Spindle
Lots of info on the board about this.
Short answer is YES you can put 71-72 drop spindles on a 69, BUT you have to change the balljoints and tierod ends (or use a complete 71-72 centerlink). There's a problem with using a 71-72 outer tierod with the 69 adjuster, you have to use a special adapter. I would like to see pictures of a factory disc brake '69... I suspect you have drum brakes all around, unless someone has changed them to disc. Use the search function, lots of good info onthis, it's been done a ton of different ways. Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
11-10-2017, 10:27 AM | #3 |
Re: drop Spindle
I'm guessing you have a truck someone already converted and you want to go from a stock height spindle to a drop spindle? GM did not put disc brakes on trucks until 1971.
If someone already converted it, you *may* already have all the "1971-1972 style" parts on it already. You need to find the part number on the spindle you have now. Every aftermarket and GM spindle I've ever seen has a P/N so it's there somewhere. You can then find out what you actually have. If you're lucky, someone put a 71-72 disc brake system on your truck. Heck, someone could have even put a 1973+ disc brake system under it.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
11-10-2017, 11:46 AM | #4 |
Re: drop Spindle
I have a swb frame with 5 lug disk up front it has 6 lug rear so I know it's been converted.... can anyone tell me how to tell if it has 71-72 stuff or square body swap please and thanks
11-10-2017, 12:04 PM | #5 | |
Re: drop Spindle
11-10-2017, 12:24 PM | #6 |
Re: drop Spindle
Like I stated above, part number on the spindle.
