Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 01-04-2019, 05:40 PM   #1
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
C60 help
Bought a c60 going to turn it into my toy hauler need lots of help is the cab and doors the same as the truck don't have it home yet has 427 in it.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 01-04-2019, 07:20 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: C60 help
No the doors have the front lower corner cut , And the lower firewall / foot board is at a different angle from the pickup even the gauge cluster is slightly different , The 427 is going to be a tall deck engine that is different from a car short deck 427 by a lot .leave it a dump truck and find something that will cruise down the highway easier .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 01-04-2019, 07:31 PM   #3
Gary 70 Jimmy
Re: C60 help
I was thinking of a 4x4 frame or a longhorns frame or a c30 frame will the c60 go on these frames with a truck bed
Old 01-04-2019, 07:42 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: C60 help
The doors are easy to modify because the inner structure doesn't need any work, and they are usually in good shape.The cabs are basically the same except for the cutouts in the doors and floorboard for the front fenders.... A friend of mine and I put a complete C50 floor in his K10 a few years ago. We had to modify the front floor where the pinch weld is but it was pretty easy.
Like Grumpy said there are some differences.
I can guarantee the floor pans are the same except for the front corners and where the trans hump meets the front toe board, and those areas aren't that hard to massage....
Here is the thread where we put the C50 floor pan in the K10:
http://67-72chevytrucks.com/vboard/s...d.php?t=490272
Here is a thread on some of the firewall area differences in the C50 and C10/20....
http://67-72chevytrucks.com/vboard/s...d.php?t=657508
As far as the cluster all you have to do is trim the plastic up to the next line where it fits around the steering column. That cluster should also have the 80# oil pressure gauge along with the Vac gauge.
LockDoc
Leon
Old 01-04-2019, 07:43 PM   #5
Grumpy old man
Re: C60 help
Sure, With a plasma cutter , welder and a bunch of fab work . They are not a plug and play conversion , Use the search option and see what others have done to use them . Body is different , fenders are different , hood is different ,interior floor is flat , even the cab corners are different ,
Old 01-04-2019, 07:48 PM   #6
LockDoc
LockDoc's Avatar
Re: C60 help
Quite a few guys have put pickup beds on the big trucks by shortening the frames. If you type "C40 pickup" into the Google search box above and click on the circle in front of "67-72chevytrucks.com" and click on the Google button you can see some.....
LockDoc
Leon
Old 01-04-2019, 09:41 PM   #7
Re: C60 help
I moved your thread to Heavy Haulers where over 1t trucks have their own place and they guys who know the most about them hang. Check this forum out to see what others have done.
Old 01-04-2019, 09:57 PM   #8
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: C60 help
That's a nice heavy truck with Wide Front Fenders. They will be hard to fill with a 1-Ton chassis. I agree, if it were mine, I would be leaving it original.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 01-04-2019, 10:31 PM   #9
5Tractorguy
5Tractorguy's Avatar
Re: C60 help
I probably sound like a broken record on posts like this by now...
Toy hauler would be really cool if you keep the original drive train and frame. Maybe pull the dump body and put a 5th wheel on for a goose neck, or extended the frame for a flat bed/ramp truck. Would look slick with a pickup behind or on it.
Could just do a newer engine and transmission too.... but if you're just going to yank the cab and front clip and stuff it on a 1-ton, find a 67-72 1-ton instead to haul stuff. Down-right tired of guys chopping these heavy haulers up.
Jake
5Tractorguy on Youtube
5Tractorguy is offline   Reply With Quote
Old 01-04-2019, 10:40 PM   #10
Gary 70 Jimmy
Re: C60 help
All the trucks I have I keeped stock. Stock to me is the only way to go. Saved this truck from going the scrap yard just wanted the gaugecluster untill he said that he only wanted $500.00 or he was going to scrap it or the next guy that came along would have scraped it I guess I saved it for now.
Old 01-04-2019, 11:06 PM   #11
C10 - C90 Bill
Re: C60 help
Glad to see that it got saved.
It looks to be pretty solid and very restore-able.
What is the GVW on it?
I'm going to guess around 24,000.
GMC 9500 Fan
Detroit Diesel Fan
Old 01-05-2019, 09:32 AM   #12
Gary 70 Jimmy
Re: C60 help
It is very solid and it is 24000
Old 01-05-2019, 04:29 PM   #13
Gary 70 Jimmy
Re: C60 help
Put it here for a reason their not many member going to the heavy hauler
Old 01-10-2019, 08:48 PM   #14
rkn463
rkn463's Avatar
Re: C60 help
Looks like chrome grill trim, headlight bezels and bumper; I'd kill for a 500 dollar truck with that stuff. Seems like it is usually just on the fire trucks.
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 01-10-2019, 10:06 PM   #15
Gary 70 Jimmy
Re: C60 help
This truck even has factory A/C in the cab first one I ever saw with A/C
Old 01-10-2019, 10:13 PM   #16
Nobighurry
Re: C60 help
May want to validate the 427. From the looks of the hood, single vent and no 427 badging, it is probably the 366. The 366 equipped trucks had the vent on my on the drivers side like this one.
Nobighurry is offline   Reply With Quote
