Old 09-02-2019, 03:08 PM   #1
Shugalou
Shugalou's Avatar
Reverse Polarity on rear bulbs
Something strange is going on when I went to replace a burnt out bulb in the rear. The signals stopped working and when I put the bulb in the wrong way the signal will work but when I seat it correctly it doesn't work.
I will be checking grounds in a few minutes but wondering if anyone else have insight into this.
Everything worked fine before the I tightening some bed bolts...Hoping it's an easy find/fix.
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 09-02-2019, 04:03 PM   #2
Shugalou
Shugalou's Avatar
Re: Reverse Polarity on rear bulbs
So after more inspecting around the front signals no longer work. I'll be searching this site for some guidance.
Old 09-02-2019, 09:35 PM   #3
Shugalou
Shugalou's Avatar
Flasher unit isn't making any noise so I will start there....I have replaced this about a year ago but we'll see if this fixes the issue.
Old 09-02-2019, 10:12 PM   #4
Shugalou
Shugalou's Avatar
Problem solved...turned out it was the flasher unit. I swapped out the hazard flasher and everything works. The one socket is kinda loose but after some shaking around it's working.
I'm looking to use the old lights for a few months than switch to LEDs
