Lift shackles for lowering kit
Hey GUys
My 97 is lowered 6in in th rear want to raise it about a inch do they make lift shackles that will fit these trucks or is their another way to do it? Thanks |
Re: Lift shackles for lowering kit
I used AC delco air shocks with shock extenders ...OEM size shocks. worked perfect.
1980 Silverado short bed 1993 GMC 1500 LS swap 2006 Lifted Z71 Crew Cab |
they make shackles, but typically they are longer and would lower more.
going shorter would drastically change how the spring flexes and cause a bucking more that likely. you could consider a rear shackle flip ??? depending on your fab skills and which holes you use... dig through some 4wd threads, or service sites for rear shackle mounts...some make a boxed version that are smaller overall than a stock and could easily be placed where needed. |
I suggest having your springs rearched for the needed lift. If my memory is right lift shackles are shorter then lowering or factory shackles. This can cause the ride to become a bit jittery due to the springs inability to grow length wide during compression.
Air shocks....
and when they leak ???? |
You fix them.. just like to fix any other line that may leak on a truck.
When I lowered my 99’ crew cab 4/6 it was a bit too low in the rear. I ordered some 1’ lift shackles off of eBay. They worked just fine.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
