Old 06-15-2020, 10:17 PM   #1
Chvy2NV
6L80 Fitment
I’ve had a few guys mention that even with the hi hump, the 6L80 might still have clearance issues? I’ve looked up a few different threads but they were older and no one really had much info on it back then.
Chvy2NV is offline   Reply With Quote
Old 06-16-2020, 02:51 AM   #2
Richard
Re: 6L80 Fitment
I should know in the near future as a 6l90 is going in my K10.
Richard
Old 06-16-2020, 07:55 AM   #3
AussieinNC
Moderator
AussieinNC's Avatar
Re: 6L80 Fitment
Hi hump will work so long as you get the engine down as low as possible...try and keep the drive line angle as flat as possible....
Also remember to use a sump that keeps the bottom of the sump above to, or level with, the bottom of the cross member...CTS-V is a good choice, assuming you are usng an LS style engine.
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 06-16-2020, 09:04 AM   #4
Chvy2NV
Re: 6L80 Fitment
Using speed engineering oil pan for LS.
Old 06-16-2020, 09:07 AM   #5
nsb29
nsb29's Avatar
Re: 6L80 Fitment
I had to go with a high hump and my engine sits as low as possible in a stock truck
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 06-16-2020, 10:13 AM   #6
Chvy2NV
Re: 6L80 Fitment
I’m running a PB Mild drop member on my setup
Old 06-16-2020, 04:06 PM   #7
First c10
First c10's Avatar
Re: 6L80 Fitment
I have Early Classic Enterprises engine mounts and trans cross member. I just massaged my low hump to make it more round on top. I did fold the flange where the firewall and hump meet. I have about 1" between the trans and the hump. its been that way for 8 years with no problems. Unless you have raised the motor I cant see a major problem.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 06-21-2020, 06:04 PM   #8
04ls1gto
Re: 6L80 Fitment
6l90 here and all I had to do was cut out lip where firewall meets floor. I used the low hump
04ls1gto is offline   Reply With Quote
Old 06-22-2020, 05:05 PM   #9
dean jendro
Old and crusty
dean jendro's Avatar
Re: 6L80 Fitment
Some good data here.
https://paceperformance.com/p-28983-...imensions.html
http://www.novak-adapt.com/knowledge...automatic/6l80
I have a high hump '64' with Early Classic engine and trans mounts and still have 3-4 inches of clearance. The 6L80 looks a bit larger in daimeter than my 4L60E but I can't imagine I would have fitment problems.
Nice having 2 extra gears, but it is not as strong as the 4L60 or 4L80.
They came out with a 6L90 shortly after the 6L80. Maybe this fixed some of the issues they had with the 6L80?
Good luck.
65 Chevy long wide daily driver - SOLD!
64 Chevy Short Step LS
dean jendro is offline   Reply With Quote
