07-01-2020, 03:35 PM | #1 |
engine rebuild?
My engine runs great, good oil pressure, doesn't burn oil, no misfires, and as far as I can tell it doesn't leak anymore oil. But I've noticed that it wasn't maintained very well because of quite a bit of sludge buildup and it's starting to develop a slight lifter tick that goes away after about a minute. I can either leave it alone, or buy the lifters and replace gaskets, or I can buy a rebuild kit and replace everything.
If I go the rebuild route, I was thinking getting a kit on rock auto with all standard sizes, taking the block and heads to a machine shop, have them hot tank them, install cam bearings, hone cylinders, and polish crank. Then I'd install/replace everything else myself. Does this sound reasonable? What would you suggest? I have most all tools needed except maybe any gauges to measure clearances. |
07-01-2020, 04:15 PM | #2 |
Re: engine rebuild?
How many miles are on it? Do you have good compression?
Assuming no major issues I would run it and do a few oil changes. Maybe run an engine flush through it right before the oil change. You can always rebuild it down the road if you have issues later.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
07-01-2020, 04:16 PM | #3 |
Re: engine rebuild?
What year and size of LS engine?
07-01-2020, 04:19 PM | #4 | |
Moderator
Re: engine rebuild?
If so, IMHO, leave it alone, change the oil and filter and use 5W 20 oil in it... After a couple of oil changes you will notice the ticking will reduce. You can remove the rocker covers and hand scrape the sludge away from the engine surfaces....sludge builds up over time when oil is not changed at correct intervals.
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
07-01-2020, 04:29 PM | #5 |
2002 5.3L. Not sure of compression.
Thanks for the replies. I did scrape/wash the surfaces I could get too but looks like there’s more in places I can’t get to. I’ll try your suggestions. Posted via Mobile Device |
07-01-2020, 05:50 PM | #6 |
Not sure of miles either.
07-01-2020, 09:18 PM | #7 |
Re: engine rebuild?
Regardless, if the motor conks out on you, it will be cheaper to replace it with a good used engine, instead of rebuilding that one.
Consider the longblock to be a throw-away item. $300 should get you a sub-150k mile bare engine. You won't even touch a rebuild for that price.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
07-01-2020, 09:48 PM | #8 |
About $600 here. Maybe a little more with that low of miles n
07-02-2020, 01:58 AM | #9 |
Re: engine rebuild?
Run her put seafoam in it help wash out the crud
If compression is good oil pressure good seafoam it I cleaned the crud out of a few 70s 350s regasket and drive em like i stole them for several years |
07-04-2020, 01:32 PM | #10 |
Re: engine rebuild?
if it's got good oil pressure, decent compression. and it's not leaking I'd just run it. Change the oil more often than necessary the first few times.
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
